Old 04-01-2019, 03:46 PM   #1
Solar
Our coach 2019, 3011DS; has the “Zamp” connection by the door.
Is there a built in controller inside the camper?
Or do you need a controller connected to the panels you connect to the Zamp connector?
The red and black wire are from the Zamp plug
Thank You; Brian French
Brianfrench65 is offline   Reply With Quote
Old 04-01-2019, 04:00 PM   #2
I have a 2016 3011 and my Zamp connector is only wiring to the batteries, no controller. I believe the portable Zamp panels have a controller on them. I decided to go with flexible panels on the roof and a separate controller. However, if I ever get to do any boon docking I could possibly use the Zamp connection for portable panels to add capacity to the 200W I have on the roof.
newRVer is offline   Reply With Quote
Old 04-01-2019, 04:10 PM   #3
Thank You for you reply.
Old 04-05-2019, 12:35 PM   #4
The Zamp connectors are a great marketing ploy, but that's about it. I repurposed the connector for my air compressor and for anything else I might want an outside 12V tap.
I had a decent solar setup on our Four Winds, (https://pbase.com/brucemac/2014solarpanels) but haven't yet gone to the effort of installing solar on the Sunseeker. It's rare that we set for more than a day, currently. After retirement in a few years, that may change.
I like Morningstar controllers - we had the Tristar 45A PWM and was pleased with it. https://www.morningstarcorp.com/products/tristar/
For maximum efficiency, you could use the MPPT controllers.
Good luck, and be sure to post your install details, should you decide to install a permanent solar setup.
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 04-09-2019, 09:42 AM   #5
Well.....it turns out that the red and black wire are from the battery disconnect switch. The red is the switched wire.
I put a Ring terminal on my solar photovoltaic wire and added a nut to the stud on the back of the switch. I have a 25 amp fuse in line, and for the ground I drilled through the floor and attached the ground wire with a ring terminal to the chassis ground stud, with an additional nut.
I used a MorningStar- ProStar PS-30M controller, with 2) 100 watt each photovoltaic panels.
ID:	201281   Click image for larger version
Old 04-09-2019, 11:15 AM   #6
See this thread.... It applies
I've been seeing a lot of "Solar On The Side" related questions. Here's some FAQs
kfergiez is offline   Reply With Quote
Old 04-09-2019, 11:23 AM   #7
Originally Posted by kfergiez View Post
Great; thank You for that link. Good information to have.
solar
