Old 04-09-2015, 01:31 PM   #1
Squeak from Entry Door
Has anyone had, and solved, a squeak from their entry door while traveling? I've put silicone on the rubber seal and it stopped it for a trip or two but it comes back. I was thinking about putting some teflon tape around the door frame.
oakprk is offline   Reply With Quote
Old 04-09-2015, 01:46 PM   #2
If the silicone spray worked, you might consider the Danko silicone paste which will stay in place.
Old 04-09-2015, 02:20 PM   #3
Wouldn't a paste type substance would collect dirt and dust after a while?
Old 04-09-2015, 02:28 PM   #4
RBR
I've have same problem. I have tried the tape and everything else I could think of. Nothing worked. If you find a solution please post it.
RBR is offline   Reply With Quote
Old 04-09-2015, 02:28 PM   #5
It might, but even with dust it would still be quiet. What have you got to loose? Don't know how you expect Teflon tape to stick and even if it did, it will wear thru.
It was just a suggestion. Nothing mandatory!
Old 04-10-2015, 02:35 PM   #6
PTFE (Teflon) adhesive tape is available on the internet. It's available in many thicknesses and with different backings. I was hoping someone had some experience with it.
Old 04-10-2015, 06:21 PM   #7
Robbsails's Avatar
I have a simular problem, but mine is from the hinges....soaking them with lubricant doesn't seem to solve the problem!
Robbsails is offline   Reply With Quote
Old 04-11-2015, 02:42 PM   #8
X2 any ideas to fix?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
door
