Old 12-31-2016, 12:25 PM   #1
Stabilizers up or down
We are newbies. First winter storing it. Its in the driveway. Should we have the stabilizers up or down or does it not matter? Thanks in advance!
gandb26 is offline   Reply With Quote
Old 12-31-2016, 12:43 PM   #2
Oaklevel's Avatar
It does not matter. Ours are always up except when camping or using the camper as a guest room.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 01-01-2017, 12:07 PM   #3
I always leave them up when stored just in case you get a flat tire. If they are down the stabilizers are not made to handle weight of the camper. Just my 2 cents.
Glen & Lee
Dawsonville, GA
2019 Primetime Sanibel 3851
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 01-01-2017, 12:32 PM   #4
Besides what has been mentioned, stabilizers down over the winter provides a good ramp for critters to find their way into the unit.
Days Camped: '17=30 '18=51 '19=58 '20=14
Old 01-01-2017, 12:35 PM   #5
Ford Idaho's Avatar
This is why they are up on my FW.
Old 01-01-2017, 01:50 PM   #6
RudysWorld's Avatar
Mine are always up in storage, but others will disagree. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 01-01-2017, 02:44 PM   #7
satdog01's Avatar
Leave mine down. Have occasional heavy wind, hope they will help the unit from blowing over if a big gust hits it. Stored on Drive with slides in. Use Cab and dryer sheets so far no mice problems.
2020 Georgetown 31L, Safe T steering, Onan Geny
2015 GMC TOAD w/Blue Ox tow plates
Pepper 🌶 Pomeranian rescue 327 nights as camping buddy
Days camped in FR, 2011-12 = 77, ‘13-14 = 98, ‘15 = 52
‘16 = 77, ‘17 = 81, ‘18 = 44, 19’ = 83, 2020 =
Retired :
satdog01 is offline   Reply With Quote
Old 01-01-2017, 03:13 PM   #8
Thanks everyone. We have a much better chance of critters than wind. They will stay up. Thanks!
Old 01-01-2017, 03:19 PM   #9
Up
If you live in area that has frost in the winter, I would leave them up. Frost heaves could raise the ground under your jacks several inches resulting in possible frame twisting. My 2 cents worth.
PeterF is offline   Reply With Quote
Old 01-01-2017, 03:47 PM   #10
Ok please don't laugh but I thought you would need the stabilizers down on a 5th wheel so the front don't tip over. Do you have the back ones up too?
Not new to camping but to a 5th wheel.
Dorrie is offline   Reply With Quote
Old 01-01-2017, 04:22 PM   #11
World Wide Wanderer
wahoonc's Avatar
Stablizers and landing jacks are two different animals. You want the landing jacks down on a FW, but not the stabilizers if you are storing it.
We keep ours up unless we are using the camper as a spare room.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 01-01-2017, 07:09 PM   #12
Mine is stored inside a heated garage. I keep the trailer leveled all the time. Keeps weight off the tires too.
340xlr is offline   Reply With Quote
Old 01-01-2017, 07:10 PM   #13
bikendan's Avatar
Always up.
Equalizer WDH
Old 01-01-2017, 07:34 PM   #14
Conservative Warrior
I usually keep mine down. The reason I do it because I use the reefer in the RV to hold beverages. It is my understanding coach should be level when using the frig. Wishing everyone a happy 2017
Vegasmailman is offline   Reply With Quote
Old 01-01-2017, 09:15 PM   #15
Better to have them up.
Brandon2
2014 2500TS
Sun Seeker
brandon 2 is offline   Reply With Quote
Old 01-02-2017, 07:13 AM   #16
DouglasReid's Avatar
You are right, the front landing gear has to be down, or you could not unhitch from your truck, could you?
They are talking about the rear stabilizers which are not designed to support much weight and neither is the frame where they are mounted. Damage and frame twisting results from too much weight being applied to the rear stabilizere, either from jacking the front while the rear are still down, or, as someone said, from a tire going flat. Neither will do your camper any good.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
stabilizers
