Old 03-21-2016, 12:07 PM   #1
Wandering's Avatar
Still Freezing - Risk?
So de-winterized the camper, heading to the beach on Thursday. Woo Hoo!
Last few nights been down to the mid-20's. Few hours below freezing not a big deal but running the arctic pack and furnace to keep things warm just in case.
Got me to wondering, what about the outside shower and the low point drains underneath the camper. Nothing to keep them warm. Anybody winter camp where they were a problem? Hoping to do a little winter camping myself next year. How do you keep those areas from freezing?
Forester 2451s
Forester 2451s
Wandering is offline   Reply With Quote
Old 03-21-2016, 09:27 PM   #2
MNtraveler's Avatar
You can dump the fresh water and use the low point drain to drain the pipes which should include the outside shower if you open it up so air can run in. Refill again when it gets warmer. Other than that, I don't know a way to keep those points warm.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 03-22-2016, 06:04 AM   #3
waiter21's Avatar
Disconnect the water supply hose and drain it.
The underside of the coach should be OK as long as there are no strong winds.
Usually these short excursions below freezing at night are a result of clear skys and thermal radiation from the ground.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 03-22-2016, 08:32 AM   #4
MNtraveler's Avatar
I forgot to mention the low point drain could be spot warmed by placing a trouble light underneath it. Just be sure the ground stays dry and you don't overheat (melt) it. Maybe the same could be done with the outside shower using a clip-on light or a pole or floor lamp.
2016 Forester 2401R
Old 03-22-2016, 11:23 AM   #5
I just de-winterized my 5er yesterday. As a matter of routine, I flush the system to look for leaks. I only found one this year. It was in the inside shower sprayer head. It's made of plastic, and apparently, when I winterized, that particular spot didn't get any antifreeze in it, so the plastic split. Have to replace the head.
In previous years, I found out that an often neglected place is in the drain pipes. So, when you run the antifreeze, be sure to run enough down each drain so that the P-traps and connections get touched by the antifreeze. Another place to check is the washer/dryer connections. On those, best thing to do is to drain them down by opening the lowest point in the camper, then opening the valves to the W/D and letting gravity suck down the water in the pipes. Do this BEFORE you add antifreeze, otherwise you will drain the antifreeze out of your system.
MOODMAN is offline   Reply With Quote
Old 03-22-2016, 03:10 PM   #6
Battery powered socks!
jboot1 is offline   Reply With Quote
Old 03-23-2016, 08:53 AM   #7
Wolverine 1945's Avatar
Not time to De-Winterize here in the Great Lakes State yet,,,
We had one morning last week the low was 18 & the next morning was 20 !!!
Maybe ok next week ???
Wolverine 1945 is offline   Reply With Quote
Old 03-23-2016, 11:00 AM   #8
MNtraveler's Avatar
A winter storm floating around here today - hopefully we won't get too much as we are on the edge, but freezing temps will still be around for at least a few more days.
2016 Forester 2401R
Old 03-24-2016, 06:15 AM   #9
Winter has returned to the North !!!
Maybe near 60 on Saturday ???
Old 04-16-2016, 12:21 PM   #10
Wandering's Avatar
Well heck, back from Florida spring break trip. Had two nights around 28 and I ran furnace and arctic pacs. Unfortunately that was not enough and froze and split the outside shower faucet. It spilt after the valve so just need to leave it off.
So much for winter camping and the value of arctic pac and heated compartments. There is always a weak link to a design. In this case outside shower and I suspect low point drain as both outside and exposed!
Forester 2451s
Forester 2451s
