Old 10-15-2016, 04:13 PM   #1
Wandering's Avatar
Storage Compartment Separating
Found my storage compartment was separating from the outside wall. Tried to tighten screws but no bite. Took screw out and found it mostly rusty. Wondering why it would rust when screwed into an outside wall. Is the wall leaking? Don't see anything open from underside.
Ideas appreciated.
Planing to use next size screw but worried.
Name:	ImageUploadedByForest River Forums1476565915.852553.jpg
Name:	ImageUploadedByForest River Forums1476565934.790775.jpg
Forester 2451s
Forester 2451s
Wandering is offline   Reply With Quote
Old 10-15-2016, 04:29 PM   #2
Head Rambler
There's a leak somewhere. You should investigate where it's coming from as it will only get worse.
Gotta go campin!
Old 10-15-2016, 04:38 PM   #3
Wandering's Avatar
Yep! Your right, gap in caulking. Hope this is it! Gonna look at all the seals. Thanks!
Name:	ImageUploadedByForest River Forums1476567453.852708.jpg
Forester 2451s
Forester 2451s
Old 10-15-2016, 08:43 PM   #4
Frank & Eve's Avatar
We had the same problem with our last compartment drivers side. Found out it is a fairly common problem with the black compartments. Re caulked, held compartment to the side with large clamps then put a bunch of new screws in. Has held for 3 years now. There are post about the separation on here.
Frank & Eve is offline   Reply With Quote
Old 10-16-2016, 09:05 AM   #5
It's a weak design. And easy to overload.
While driving in rain, water will splash up onto that attachment area from below. If water was getting in from the interior, you'd know it.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 10-16-2016, 10:17 AM   #6
re
Maybe replace with stainless steel screws?
poppytoymaker is offline   Reply With Quote
Old 10-16-2016, 11:54 AM   #7
Left Coast
Add more ss screws....
Old 10-16-2016, 04:41 PM   #8
sgtlm17's Avatar
Wandering
My 2016 2801 storage areas look like yours but they still feel solid
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 10-16-2016, 05:04 PM   #9
Been told it's just the black ones that have the problem. The grey ones are the improved ones.
Old 10-16-2016, 05:51 PM   #10
sgtlm17's Avatar
Mine are grey. . I have seen the black. . The grey appear to be stronger and more rigid.
2011 Jeep JK Toad
storage
