Old 06-30-2015, 08:29 AM   #11
Ford Idaho's Avatar
Originally Posted by SkipnTerri View Post
I removed the cowling and cut pieces of the double-foil insulation to fit the metal doghouse. On the advice of the HVAC guy, I used sticky-back pushpins and then sprayed contact glue onto the doghouse and attached the insulation to it. Last, I snipped off the tip of the pin before replacing the cowling.
I tried to find sticky push pins, what are those?
Old 06-30-2015, 11:28 AM   #12
Hopefully this picture loads. It shows the cap, pushpin (with sticky back), and piece of insulation. Make sure to clean the metal surface doghouse where you want the pushpin. They don't come off.
SkipnTerri is offline   Reply With Quote
Old 06-30-2015, 08:08 PM   #13
Ford Idaho's Avatar
Thank You for that, now know what I am looking for.
Old 07-03-2015, 01:06 PM   #14
Garrette's Avatar
Have you finished the job? Not much room for insulation. Did it fit ok? Got a pic of the finished job?
Garrette is offline   Reply With Quote
Old 07-03-2015, 06:22 PM   #15
We're currently on the road headed to Colorado and giving all the insulation a good test in Kansas. It definitely is making a difference. The a/c improved and is actually cycling normally on the auto mode. We didn't have to use an additional fan to cool down either. Tomorrow will be an even better test in 90+ temps. Will keep you posted.
Old 07-04-2015, 03:42 PM   #16
West Cactus's Avatar
RV SunShade Company Products
These look perfect for the sunlight covers!
West Cactus is offline   Reply With Quote
Old 07-04-2015, 05:34 PM   #17
Wish I could download a pic, but connection is poor at best while on the road. Temp is currently 93 degrees and our interior is 81. We are right directly in the sun.
forester
