Old 06-30-2016, 07:38 AM   #1
Surround sound
On the 2015 Forester 2801 GTS, does the TV at the table have surround sound attached to the ceiling speakers? I receive sound from the Jensen radio through the speakers but I cannot figure out if the audio from the TV will go through the same speakers.
rgrill6211 is offline   Reply With Quote
Old 06-30-2016, 08:24 AM   #2
sgtlm17's Avatar
Yes absolutely. Turn on the coach Jensen radio and select hdmi mode
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 06-30-2016, 08:31 AM   #3
Tombsy's Avatar
Surround sound
On mine it's a bit different, you have to select AV2 on the Jensen and set the front/rear fader to rear. You also have to change the audio out on the TV, if I remember right you change it from variable to fixed. You only have to do that once if you use the surround from now on.
Brian
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 06-30-2016, 08:54 AM   #4
sgtlm17's Avatar
They must have changed it on the 2016 models. No settings to change on TV. Simply mode selection on radio.
Brian or Josh posted a FR video on how to change the TV and stereo for the earlier models. . I think it was on Facebook
2011 Jeep JK Toad
Old 06-30-2016, 09:26 AM   #5
Tombsy's Avatar
I think they went from our composite cables to HDMI on yours.
Brian
Old 06-30-2016, 12:22 PM   #6
When I go to the rear TFT on the Jensen control panel, it shows rear "off" with the universal no symbol. How would one turn that "on"? I would assume that would have to be on in order for the surround sound to work in the rear portion of the motorhome.
Old 06-30-2016, 01:22 PM   #7
Tombsy's Avatar
Surround sound
I don't use the rear TFT at all, just AV2 and slide the fader to rear, you get to it thru the equalizer screen.
Edit: I just remembered the rear TFT is for a rear camera
Brian
Brian
Old 06-30-2016, 04:21 PM   #8
Surround sound
Thanks Brian, I will give that a try.
Bob
