Old 09-11-2018, 12:29 PM   #1
Switch under left side of drivers seat
Is this switch used to start Chevy cab with house batteries and if so ,how?
poppytoymaker is offline   Reply With Quote
Old 09-11-2018, 12:32 PM   #2
Duckogram's Avatar
It starts Fords too. You push the button and turn the ignition key.
ILB
Old 09-11-2018, 03:51 PM   #3
Eject!
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 09-11-2018, 04:36 PM   #4
The reason I ask is that I had it detached when I removed the seat and not sure I rewired it right. Is the hot wire on the bottom or on the top when you close the contact?
Old 09-11-2018, 08:32 PM   #5
Duckogram's Avatar
Dont know how yours was wired. They are not the same model to model or even year to year same model. I suggest a meter to find out.
ILB
Old 09-12-2018, 06:04 AM   #6
If there are only 2 contacts on the switch wire position does not matter. The switch provides a connection between the 2 wires when held depressed.
When you activate the switch (with engine off and shore/generator power off) you should hear a clunking sound coming from your battery control center, it’s typically in the stairwell on a forester.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
switch
