Old 02-20-2014, 02:21 PM   #21
Originally Posted by ATVer View Post
I got it on Ebay. At the time there were a number of new takeouts available but I just checked Ebay and could not find any. I could not find a part number on it and though maybe it was aftermarket. However the issue came up on this forum a year or so ago and Bclemens from FR looked into it with Ford. He found it was a factory Ford part and they were still available at the time but only in Gray. You might be able to find it or another used somewhere. There have been a number of iterations over the years.
Thanks...I'll keep looking around and will also check again with Ford...
jrwalkerpa1 is offline   Reply With Quote
Old 04-11-2014, 09:18 PM   #22
Does anyone know where I can find a diagram showing how the swivel seat bracket for a 2013 Sunseeker 3010DS goes together? I want to install it myself and it came with multiple pieces.
jfortin is offline   Reply With Quote
Old 04-14-2014, 07:46 PM   #23
Yes I would like to do that also. Where did you get the swivel base from?
rekwiat is offline   Reply With Quote
Old 04-14-2014, 08:33 PM   #24
For my 3010DS, I got the bracket from a Forest River dealer.
The bracket is made by Atwood part #486230.
I am still waiting to find out where to two flat metal pieces go.
Old 04-15-2014, 04:55 AM   #25
We took the armrest off the couch behind the passenger seat in our 3051s to allow it to recline some. It is much better than no recline at all. This is the only thing I do not like and wonder if it was an engineering FUBAR, or done on purpose. I will be looking for the slimline doghouse because I can't see smacking it as hard as I did to remove while going down the road. Leaving it off is no good due to loss of storage and cup holders.
USNMM1VETERAN is offline   Reply With Quote
Old 11-22-2014, 07:55 AM   #26
Truck,vans has a universal swivel base 110001 with 3 different bolt patterns wonder if it would work on a E450 ford 2015 forester? The one bolt pattern looks like it would fit. Any info. Thanks
jazzy47 is offline   Reply With Quote
Old 11-24-2014, 09:49 AM   #27
GM
bclemens's Avatar
1. I think they sent you some extra parts that go to our power pedestal.
2. I am checking on that now...we think the Atwood swivel per should just be in one piece.
3. I'll confirm that shortly.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 11-24-2014, 11:25 AM   #28
GM
bclemens's Avatar
OK, so I confirmed this with production.
Install the swivel ped first.
There are (2) flat metal plates, those go on after. When you slide the seat over (45 degree angle) that leaves a big gap where you can see the floor. Those plates are called "pinch plates" they just clip over that hole using christmas tree plastic bolts? push pins?. That keeps you from getting your fingers caught in that hole somehow when sliding back.
Old 12-09-2015, 06:52 PM   #29
Will the Atwood swivel work on a 2015 2801QS?
AbdRahim is offline   Reply With Quote
Old 12-10-2015, 02:47 PM   #30
Would 113530 & 113531 from http://www.discountvantruck.com/rvva...dseatbases.htm work on the Forester 2801QS? What is the advantage of the Atwood for more than twice the price?
