Old 06-10-2014, 12:19 PM   #1
Tail lights blown
Both driver side tail lights are blown. Time for some silcone to solve this problem. 2015 3011ds. Anybody else have this issue?
Phelpo
phelpo is offline   Reply With Quote
Old 06-10-2014, 12:27 PM   #2
mjones12's Avatar
I had a similar issue on my previous Surveyor trailer. The taillight/brake light lenses did not fit flat against the light housing. Maybe they warped a little over time. In any case when it rained, water would get in the gap and blow the hot bulbs. I countered with a strip of white electrical tape, which cured the problem. I figured the tape would be easier to remove than silicone if I ever needed to replace a bulb, but I never needed to.
I've noticed on my new Surveyor that there is a little ledge above the lens that helps keep water from getting in, even if the lens warps a little bit.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 06-10-2014, 03:45 PM   #3
Revised to 3 blown bulbs
Old 06-10-2014, 09:26 PM   #4
Lots of people have had the same issue. I used bulb grease along the top half of the lens. Left the bottom half unsealed and drilled a small hole to drain out anything that might get in before it built up enough to splash around and kill the bulb.
ATVer is offline   Reply With Quote
Old 06-10-2014, 10:11 PM   #5
Same problem bulb grease did not work. I silconed the top of the lens cover. Np since.
MikeRP is offline   Reply With Quote
Old 06-11-2014, 09:04 AM   #6
Replaced the three and sealed them up. Hopefully no more blown bulbs
Old 06-11-2014, 11:48 AM   #7
2012 Solera
Our 2012 Solera uses Bargman 84 LED tail lights. Not sure if Forest River also uses Bargman 84 lights on the Foresters. If so, Bargman offers an LED retrofit: Amazon.com: Bargman 47-84-410 Red LED Upgrade Kit for #84/#85/#86 Series Stop/Tail/Turn Light: Automotive
The Bargman LEDs on my vehicle are sealed capsules - should be no water incursion problems.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-11-2014, 06:19 PM   #8
ran thru a ton of rain in Georgia, they came thru and work after the
down pour
Phelpo
light
