Old 01-02-2019, 12:13 PM   #1
Bezzola's Avatar
Thermostat
I have the forester 3011
The thermostat is in the rear bedroom has anyone ever reloctated it to a more central area. We use the rv in the fall in Alberta and find if we close the bedroom door the the people sleeping out front are cold.
Bezzola is offline   Reply With Quote
Old 01-02-2019, 07:32 PM   #2
Originally Posted by Bezzola View Post
Anyone ever relocated on before
I have not but its just low voltage wires, if you can find a route from new to old location, or from furnace to new location it shouldn't be too hard. Or leave the bedroom door open so air circulates better. Another option is to undercut the bedroom door so there's at least 1" clearance to the carpet for air flow.
nayther is offline   Reply With Quote
Old 01-02-2019, 07:55 PM   #3
Who Dares, Wins
doc73's Avatar
On a previous TT I moved the thermo since they put it behind a slide and in a corner so it did an even worse job managing the temp. Once moved it worked better. Used thermostat wire from from home depot, the 2 wire type.
Our new 5er, the thermo is apparently a ethernet type data cable so I do not know if it could be moved a easily.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 01-03-2019, 08:20 AM   #4
RedLdr1's Avatar
If you need to move it a RJ-45 coupler is easier than slicing wires. Use a coupler and a straight thru RJ-45 pre-made cable to extend it where you want it.
That's a quick fix that saves buying a RJ-45 crimp tool for one project...
Wayne and Christine
2019 R-Pod RP-180 10th Anniversary Edition
2018 Ford F-150 SuperCrew Lariat FX4 (4X4) 3.0L Power Stroke Diesel
RedLdr1 is offline   Reply With Quote
Old 01-03-2019, 10:05 AM   #5
Bezzola's Avatar
Perfect thanks
thermostat
