Old 11-10-2014, 10:00 AM   #11
Am i missing something? The OP said he has dual rear axle, so would the 9700lbs not be on 4 tires?
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 11-10-2014, 10:09 AM   #12
You are right but the lists of Michelin gives it for 2 tires in the dual load line.
Yust what they think is easy how they make the list.
In Europe where I live, these lists are given per axle , so single load gives 2x maximum tireload single and dual gives 4x Dual maximum load ( Dual max load is 0.925 times single maximum load per tire, America uses often 9% reduction so Dual = 0.91 x Singlemaxload. this is to make it easy for the user, but its the same as computer programmes , sometimes this is anoing for the user, my cursur often is in a totally different space somtimes wich is also meant for comfort of the user but mostly only anoying.
jadatis is offline   Reply With Quote
Old 11-10-2014, 10:28 AM   #13
Thanks, should have looked at the chart closer.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
pressure, tire
