Old 08-18-2016, 12:08 AM   #1
raptor's Avatar
Tire-Safeguard monitor and valve stems help
After reading a lot treads in here about adding tire safeguard monitor. It looks like I have to change all valves to steel stems, but have idea what to do. I've found this valve kit in camping world that will fit my MBS 2401R (Dually valve 2013-current Sprinter 16" steel round 1.5" class B or C #84727 for $80). My questions is about front wheels kit? If you've done this to your RV and it works for you. What setup do you have? Also I've found valve extensions on my dual tires from MS just hanging there a couple threads in and can't check air pressure from there.
raptor
2016 Forester MBS 2401R
America is great
raptor is offline   Reply With Quote
Old 08-18-2016, 07:04 AM   #2
CharSolera's Avatar
Raptor, call 'Your Tireshop Supply' at 818-481-2817. Web: http://yourtireshopsupply.com. They're very helpful and will set you up with what you need.
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 08-18-2016, 11:34 AM   #3
raptor's Avatar
Thanks Charlene I've just ordered DL1SP13FR kit with 2 1/4" front stems.
raptor
America is great
Old 08-19-2016, 03:08 PM   #4
Raptor, same kit I had installed on my 2401r. You may not be able to get rear inside wheels balanced due to interference between long valve stems and balancing equipment. I had the other 4 wheels balanced and haven't noticed any ride/wear issues yet.
normtre is offline   Reply With Quote
Old 08-20-2016, 01:39 AM   #5
raptor's Avatar
Thanks normtre. I'm going to have Tire-safeguard flow through caps. I've read treads here that they could cause even more on balancing because they are larger then non through caps. I am anxious to see how far would it stick out especially front stems. Next week I will find out then I will post pictures.
raptor
America is great
tire
