Old 04-04-2018, 05:59 PM   #11
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Originally Posted by Keystoner View Post
The smell could be from an internal water leak of the toilet that does not run out onto the floor. DOMETIC had a recall. The seal between the bowl and pedistal may be leaking "dirty" water. The back of the toilet has a large opening for the smell to come out and water to evaporate. I was able to hold my cell phone camera behind the toilet and take pictures of the inside.
If that doesn't make sense, think of the toilet as 2 soup bowls stacked one on top of the other. There is some space between the bowls. The top bowl is leaking a little bit into the bottom.
Yes, that's a possibility.
We had this 'leak' a few years back, I took the toilet bowl off of the pedestal reseated the gasket and put it all back together. Took me about 1/2 hour incl. cleanup. Never had a problem since, no smell no leaks.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is online now   Reply With Quote
Old 04-04-2018, 06:16 PM   #12
I had the same problem with my 319MBS - took it to the dealer and it was the same problem as cypressloser - dealer fixed it and no leaky since.
Jeff & Peggy
2017 Coachmen Leprechaun 319MBS
Avid campers since 1999
Jcf0527 is offline   Reply With Quote
Old 05-28-2018, 11:49 PM   #13
2018 Rockwood 2703WS
Houston Remodeler's Avatar
Thanks to everyone who contributed !!
We located the source of the rank odor after reading this thread, grabbing a flashlight and using our nose.
We have the same bowl-inna-bowl problem.
Took it apart, cleaned out the maggots (eek, they were tiny though), sterilized everything, then re-assembled.
Keeping our fingers crossed.
2014 Ram 2500 4x4 diesel
guarded by our Jack Russell
Houston Remodeler is offline   Reply With Quote
