04-03-2018, 09:03 PM
Toilet troubles
We have our 2018 3011ds out on it's inaugural trip and have had to fix several small and one large problem. One that has me confused is the toilet leaks behind the wooden spacer behind it occasionally and then stops. Also the bathroom really smells all the time even though I keep a lot of blue stuff in the toilet. We have had at least 5 other campers in our lives and have never had one that smells this badly. Do you think the vent pipe could be clogged? The rig is brand new so this seems unlikely but not sure what else could be causing the smell. The toilet itself isn't leaking, but a water pipe in the wooden spacer, I believe. Line may have frozen before we bought it new front the dealer. I think this is a separate issue and not related to the bad smell, but not sure.
Any thoughts?
04-03-2018, 09:25 PM
Certified Curmudgeon
Water pipe leak is bad news. Top priority repair. Smell issue can be a plugged vent but may not be the black tank. Could be under the bathroom sink.
If you post pics the gang would have an easier time translating what you are talking about.
Mike Dropped
04-04-2018, 11:46 AM
I'm sorry but I don't know how to post a picture. I read the FAQ and didn't help. When I click the photo option above it asks for URL and I don't know what that is or where to find it> I did click on add video and choose file and downloaded the photos but they don't show up when I post.
I was able to post a photo from my phone, not the computer.
04-04-2018, 12:00 PM
Check under the bathroom vanity. many units use a vacuum breaker that is mounted under the sink. These are notorious for failing open and allowing odors from the grey tank to enter the bathroom. If you have one, you can tap on it to try to reset it but it will need to be replaced eventually. Valve looks like below.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-04-2018, 12:06 PM
Thanks for the reply. Water leak is from under the wooden area
04-04-2018, 12:08 PM
I am installing a new toilet this summer. DW says the flush water does not go around the bowl all the way leaving a smell.
As for pictures. Go up to the paper clip next to the happy face the dodad bar. click on "choose a file". you pics will be available. Pick one and open it. A new window will open. click download file. then go to preview as see what you got.
then click "submit reply"
04-04-2018, 01:32 PM
The smell could be from an internal water leak of the toilet that does not run out onto the floor. DOMETIC had a recall. The seal between the bowl and pedistal may be leaking "dirty" water. The back of the toilet has a large opening for the smell to come out and water to evaporate. I was able to hold my cell phone camera behind the toilet and take pictures of the inside.
If that doesn't make sense, think of the toilet as 2 soup bowls stacked one on top of the other. There is some space between the bowls. The top bowl is leaking a little bit into the bottom.
04-04-2018, 02:48 PM
Well it looks like you have the pic posting mastered. Well done. FlyBob’s post is a perfect example of the vent.
Keystoner’s post reflects a possibility as well.
The box behind the toilet is basically a cable chase. If there are water lines in it there should not be a junction. So look into the cabinet on the right and possibly up into compartments below. Water can travel quite a ways before it finds a way out.
Mike Dropped
04-04-2018, 02:55 PM
The water supply line to the toilet, and both the hot & cold lines to the bathroom sink are back there ! If you have not, check the connection(s) behind the toilet, and both under the sink.
Those are fresh water lines and should not have an odor. Toilet checked for tightness to floor ? Running exhaust fan while flushing can suck the black tank flumes back up into the bathroom.
1930 lbs CCC
2014 Jeep Rubicon JK
04-04-2018, 04:39 PM
Any thoughts?
I have a 2016 3011 that had a leak in the same area. That wooden spacer should just have cables and water lines in it. The leak in my unit turned out to be a broken 90 degree PVC elbow on the other side of the bathroom wall where the water lines connect to the outside faucet. I did end of replacing both of them with brass connectors to avoid having the same issue again.
http://www.forestriverforums.com/for...ll-142452.html
It's possible that that you have the same issue and the water is just leaking out from the lowest point which is from under the wooden spacer. Or it may be that the water connection inside the spacer has the same PVC elbow and it has a crack in it.
04-04-2018, 04:59 PM
Location: Alberta - East of the Rockies, West of the Rest
Yes, that's a possibility.
We had this 'leak' a few years back, I took the toilet bowl off of the pedestal reseated the gasket and put it all back together. Took me about 1/2 hour incl. cleanup. Never had a problem since, no smell no leaks.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
04-04-2018, 05:16 PM
Jeff
I had the same problem with my 319MBS - took it to the dealer and it was the same problem as cypressloser - dealer fixed it and no leaky since.
Jeff & Peggy
2019 Coachmen Mirada 35BH
Avid campers since 1999
05-28-2018, 10:49 PM
2018 Rockwood 2703WS
Thanks to everyone who contributed !!
We located the source of the rank odor after reading this thread, grabbing a flashlight and using our nose.
We have the same bowl-inna-bowl problem.
Took it apart, cleaned out the maggots (eek, they were tiny though), sterilized everything, then re-assembled.
Keeping our fingers crossed.
2014 Ram 2500 4x4 diesel
guarded by our Jack Russell
