Old 11-27-2015, 12:01 PM   #1
Tow vehicle brake requirements
i'm adding a Honda Fit toad to my Forester 3051s. It's about 2500 lbs. My blue ox dealer doesn't think i especially need a braking system. Since it about doubles the cost of the tow setup i would prefer to avoid it too.
What i don't know if how much risk i have of being ticketed in states that require tow brakes. My research shows there aren't many states where i would be in violation. What is the reality out on on the open road?
Thanks for your response.
2016 Forester 3051SF
MMulcahy is offline   Reply With Quote
Old 11-27-2015, 04:35 PM   #2
RedLdr1's Avatar
While you may be under the max weight limit in most states you still need "Break Away Brakes" in those states. How do you plan to handle that requirement?
See Here and Here for a State by State guide...
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
RedLdr1 is offline   Reply With Quote
Old 11-27-2015, 05:18 PM   #3
bubbles's Avatar
The OP is talking about a TOAD behind a motorhome not a trailer. What's with the break away brakes? Toads just have safety cables as part of the setup.
Old 11-27-2015, 05:19 PM   #4
CSMRetired's Avatar
X2
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
CSMRetired is offline   Reply With Quote
Old 11-27-2015, 06:27 PM   #5
Boso's Avatar
It's nice to have the extra braking when you need it I used a brake buddy for years on three different toads but now I'm using nothing my toad is about 32-3500 lbs my Rv is a 3050s but you have to be careful in heavy traffic. I will buy another brake buddy as soon as I find one at a great price I have about 6000 miles on Rv at this time without anything if I was towing less than 3000 lbs I wouldn't buy one just my opinion
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 11-27-2015, 06:52 PM   #6
Kenny kustom's Avatar
I would put brakes on it.
It might not be your life you save.
2017 Dynamax Isata 4
Old 11-27-2015, 07:38 PM   #7
So are u saying that a toad is different than a trailer, and the same rules don't apply?
rekwiat is offline   Reply With Quote
Old 11-27-2015, 07:42 PM   #8
My tt had safety chains. And a break away.
Old 11-27-2015, 07:43 PM   #9
3000lbs @ 60mph turns into 363000 lbs of kinetic energy.
Old 11-27-2015, 07:44 PM   #10
bubbles's Avatar
When it comes to any requirement, referencing "breakaway braking", for our TOAD application, that is correct.
Old 11-27-2015, 07:47 PM   #11
Blue ox patriot. Under $950 and has break away.
Easy.
Old 11-27-2015, 07:48 PM   #12
CSMRetired's Avatar
Big difference when you have a 20,000 lb vehicle pulling a 3,000 lb vehicle
Vice a
3,000 lb vehicle pulling a 20,000 vehicle
'Pa Pa's Palace'
Old 11-27-2015, 08:04 PM   #13
CSMRetired's Avatar
Towing World Official Website
Check each state
Brake laws for towed cars
'Pa Pa's Palace'
Old 11-27-2015, 08:18 PM   #14
Witch Doctor's Avatar
I always thought it is what your register State requires? Just like Calif. You need a class B for a M/H 40' I think, but if your traveling through it, It doesn't apply to you unless your state requires it.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-27-2015, 08:26 PM   #15
CSMRetired's Avatar
Correct
Otherwise you would have to set up your rig for the most stringent states towing law in order to travel anywhere
'Pa Pa's Palace'
Old 11-27-2015, 08:49 PM   #16
Originally Posted by CSMRetired View Post
Correct
Be sure to check with the state.
For instance.
You cannot triple tow in British Columbia. Even though, it's allowed in say, Alberta.
You will get turned around and sent away.
Old 11-27-2015, 08:51 PM   #17
CSMRetired's Avatar
For instance.
That's a common sense factor, but setting up your towing system for California when you're registered in Oklahoma is not common sense
'Pa Pa's Palace'
Old 11-27-2015, 09:08 PM   #18
RedLdr1's Avatar
That is not correct in all jurisdictions. Break away brakes are a requirement in several states. The chart Here, albeit a little out of date, shows 37 states, the ones with a *, that require a break away system on a TOAD that exceeds the state brake weight requirements. A call to your local DMV will find out the actual requirements for your state. Take a look at Page 27 of the 2015 Motor Home Dinghy Guide for their take on the issue.
IMHO if you're towing without a braking, or break away, system installed you are looking for trouble. If you get into an accident you just may find trouble. Everyone is welcome to do what they think is "right" but don't complain if it comes back to bite you...
Wayne
Old 11-27-2015, 09:27 PM   #19
CSMRetired's Avatar
Most, if not ALL references to towing are talking about trailers....there is where I feel a lot of confusion comes in to play. Towing with a motorhome is completely different than towing with a pick-up or a standard vehicle. The question is the 'legality' of the matter.....again. .. common sense. Also, keep in mind that a toad brake manufacturer is going to say enough to try to potentially scare someone into buying something they may not need. I'm not saying I don't agree with the need for auxiliary brakes....I'm just saying it's not necessarily 'law'
'Pa Pa's Palace'
Old 11-27-2015, 09:38 PM   #20
It's not illegal for me to stick my bloody hand into a tank full of piranhas..
I just know, it's not a great idea.
Common sense, isn't so common.
tow vehicle, brakes
