Old 01-04-2014, 10:48 AM   #1
Frank & Eve's Avatar
Traveling with the windows open ??
OK here's another question. Is there any reason why you shouldn't ride down the road with the slider windows open in the coach?
Frank & Eve is offline   Reply With Quote
Old 01-04-2014, 11:09 AM   #2
Mike001's Avatar
Can't think of a reason not to, I don't usually do it. I leave my roof vents open while driving.
Mike001 is offline   Reply With Quote
Old 01-04-2014, 11:15 AM   #3
B47
Unless I'm missing something here, I'm assuming the slider is retracted while your moving.
So what benefit would you be gaining if ventilation is what your seeking by having them open?
Old 01-04-2014, 11:22 AM   #4
So what benefit would you be gaining? if ventilation is what your seeking by having them open?
Well wouldn't it be like having your window rolled down up front with the sliders open in the coach?
Old 01-04-2014, 11:24 AM   #5
Tks I'll try that too. Sometimes just a little extra air is all that is needed back there.
Old 01-04-2014, 11:27 AM   #6
B47
I guess it would - as previously posted,I can't think of any reason not to as well as any reason to.
Does your owners manual give any cautions about traveling with them open?
Old 01-04-2014, 11:34 AM   #7
Professional Curmudgeon
wrvond's Avatar
No reason not to. Simply advise your passengers to "keep their heads and limbs inside the vehicle at all times" and you should be good to go.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 01-05-2014, 08:42 AM   #8
The roof vents are able to stay open while driving? I always close them. I thought the little piece of aluminum that props the vent open doesn't look strong enough to hold up to a 65 MPH wind.
paulmlac is offline   Reply With Quote
Old 01-05-2014, 09:03 AM   #9
Mike001's Avatar
I have Maxi-vent covers on all my roof vents, that's the first modification I did. They are rain proof, never had one leak, even in a downpour. If you forget and leave a vent open w/o a cover, it is a mess.
Old 01-05-2014, 06:08 PM   #10
The only issue I ever had was that the air pressure differential could cause some sewer smells to come in...sort of the same reason you may not want the bathroom fan on while flushing.
But, even that is rarely an issue if the toilet is sealing and holding water properly and your tank vents are working.
jrwalkerpa1 is offline   Reply With Quote
