Old 09-15-2014, 08:47 PM   #1
TV
My outdoor Jensen TV won't turn on but the power source is on. TV won't turn on remotely or manually. Any thoughts out there!
coldj is offline   Reply With Quote
Old 09-15-2014, 08:54 PM   #2
mcnabbwr's Avatar
Have you plugged anything else in to verify outside power? Maybe tripped GFI.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 09-15-2014, 09:05 PM   #3
The lights and refrigerator are working and the red light on the plug in is lit.
Old 09-15-2014, 09:13 PM   #4
mcnabbwr's Avatar
Are they plugged into the same outlet? If not plug a light, fan or other into outlet to verify power. I am assuming its 110v.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
Old 09-15-2014, 09:18 PM   #5
VinceU's Avatar
Is it still under warranty? If not you can call and ask tech support if there is a fuse inside the TV cabinet. Otherwise its off to a TV shop, its the power supply, the most failed section of all.
Old 09-15-2014, 09:23 PM   #6
I plugged in my GPS since it has the cigarette lighter type plug in and it worked. TV was working fine the other day. It is still under warranty.
Old 09-18-2014, 03:03 PM   #7
GM
bclemens's Avatar
TV is 12V. Sometimes low batteries will not permit the TV to operate. Might just be the power cord too.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-19-2014, 11:26 AM   #8
Thanks Mr. Clemens. I applaud and admire your participation, help and information you provide for FR. Will check the cord. I do hear something rattling at the plug in end when I shake it. Sounds like something came loose.
Old 09-20-2014, 08:48 AM   #9
My center tv (bunk area) stopped working. No blue light on the tv so I figured it had to be power related. Investigated and found the inline fuse was loose. I think it is missing the internal spring in the fuse cartridge - there's no pressure on the fuse from the leads and to make it work I have place the fuse holder in such a way to apply enough pressure to make contact.
Bobby
bgilly is offline   Reply With Quote
Old 09-20-2014, 08:53 AM   #10
VinceU's Avatar
Replacement in radio shack for a couple bucks. Good invest if bunks are used.
