Old 02-14-2017, 06:10 PM   #1
TV and Radio Reception in 3171
We have great reception when we watch television on our over cab Jensen television when we are hooked up to cable at an RV park. However, the TV reception on the bunk area TV and bedroom TV is fuzzy. Also, we get very few radio stations on the radio in the bunk area. DH pulled the radio out from the console and said it looks like the radio unit is properly connected.
Any suggestions on how to get better TV reception and more radio stations?
Thanks.
Pixey is offline   Reply With Quote
Old 02-16-2017, 04:18 PM   #2
sgtlm17's Avatar
I believe the radio antenna is split and uses the Ford hood antenna and is a common complaint of poor radio reception. You can try a separate radio antenna attached to the coach roof.
If your getting good reception on the main TV but others are fuzzy it sounds like an interior wiring problem or possibly a splitter. Start with checking connections.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
radio, reception
