I'm trying to diagnose poor TV reception on our 3051 MH. Winegard Sensar antenna with Magnadyne Video Control Switch (VCS-10). I haven't been able to locate an antenna amp plate as is shown in Winegard owner manual.
Does anyone know if there's a antenna amp on this coach model? IF so, where is it?
It appears that the Magnadyne switch box is the only amp in the system. The switch box has a 12v feed. I verified that the 12v feed is OK up to the connector, but can't tell if the switch box is working since it does not have a LED or on/off switch. We have nearly 30 available channels (including sub-channels) in Detroit metro area. I get only 2-4 ch thru the switch box. Get 10-12 when ant is connected directly to the TV (ant would not be amplified in this case). But I get 22 ch with a set of amp. rabbit ears sitting inside the coach!
I checked with Magnadyne tech support and they informed me that their switch box only uses the 12v to convert the RCA input (from DVD) to a signal for output on coax. It has no antenna / signal amp function. This is really starting to "bug" me. I've had several trips now with zero TV reception. Those 3 TV's in my coach are going to waste!!
