Old 06-24-2015, 08:10 PM   #11
GM
bclemens's Avatar
For cable you don't need to do anything. Middle connection is Roof sat pre-wire.
You only need to disconnect jumper if using a portable sat hooked into the cable connection outside on the wall. The jumper is to tie into a sat receiver. See attached.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 06-24-2015, 08:26 PM   #12
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
Thanks! It's great having you and Joshua on board to answer our questions.
Forester Fred is offline   Reply With Quote
Old 06-25-2015, 07:49 AM   #13
Those little green booster lights are necessary and only if using TV antenna. If you have it ON and hooked to CABLE, your SCAN will NOT operate as you would expect. I mess mine up all the time.. Button on, button off, 😁😡
SilverbackMel is offline   Reply With Quote
Old 07-01-2015, 04:20 PM   #14
bclemens: Do you have a TV schematic for 3051S? Does this model have a separate antenna booster? ours is a 2013 with the Magnadyne VCS-10 video box. Any way to tell if the Magnadyne box is operating correctly? I'm only getting 3 ch in Detroit metro area (2-1,2,3) without the box. No channels with the box. I've been able to pickup 30 total channels with a pair of amplified rabbit ears inside the coach.
dcogs15 is offline   Reply With Quote
Old 07-01-2015, 04:27 PM   #15
GM
bclemens's Avatar
If you're getting 30 channels with rabbit ears and none with the box...I'm guessing something is amiss. I was always told the booster was built into the box. Someone else said Magnadyne stated the opposite.
antenna
