Old 06-22-2015, 08:33 PM   #1
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
TV antenna questions
Hello fellow FROGgers....it's official, I picked up my Forester 2301 today and it's sitting in my driveway. The dealer did a good job with the pre delivery inspection and explained everything really well. The coach has a King Jack tv antenna, not the old style crank up one that I had on my old camper. It's the digital antenna that stays up all the time (low profile). When the dealer did the walk through with me he showed me the on/off switch on the interior part of the antenna and told me that I had to turn the antenna on to use it. Well, when I got home I fired up the front TV and switched on the antenna....nothing happened. I had the TV do a scan for channels (after making sure the TV setting was on "air" instead of "cable". Still nothing. There are LED lights on the interior antenna mechanism but I didn't see them come on.
I found where the TV is plugged in to power and the antenna inside the cabinet over the door. But, there's also another TV cable plate that has 3 connections with a jumper cable between 2 of them. What's up with that? Do I need to switch the cable from one position to another to use the antenna? I didn't know if the antenna received power through the TV cable or not. Nothing in the literature explained any of it. Any help would be greatly appreciated.
Here's a photo of the inside antenna portion. (I checked on the roof and didn't see any power cables or connections up there for the antenna.)
Here's the wall jack with the 3 connections and jumper cable.
Forester Fred is offline   Reply With Quote
Old 06-22-2015, 08:47 PM   #2
Just thought of something. The coach has a second TV in the bedroom - would that be the reason for the jumper cable?
Old 06-22-2015, 09:07 PM   #3
OK, just answered my own question. Went to the King website and saw that they were showing a power switch on the plate that the antenna connects to. I didn't notice this switch until I looked at the photo above - the one that shows the 12v plug for the TV in the white plate and the brown plate with the 3 connectors and the jumper.
I just pushed in that little hidden button and everything came to life. I now have an operational antenna.
But, the question regarding the 3 connections and the jumper cable still stands. Do I need to change where the cable is attached when hooking up to cable TV in a campground?
Old 06-22-2015, 09:49 PM   #4
jaibyrd's Avatar
No need to do anything with that jumper panel. Just hook up to cable and change tv setting from air to cable and you are good.
Snyder Family - Pelham, NH
2015 Sunseeker 3170DS
jaibyrd is offline   Reply With Quote
Old 06-23-2015, 07:59 AM   #5
Citrus County, Fl.
GL1800Rider's Avatar
Just had our PDI walk thru on Thursday. It was explained to me the jumper is for the satellite connection.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 06-23-2015, 08:50 AM   #6
When using cable TV you need to jump position 2 & 3.
steverkemp is offline   Reply With Quote
Old 06-23-2015, 09:18 AM   #7
jaibyrd's Avatar
I didn't have to jump when I plugged into campground CATV. I think you need to jump when using the rooftop satellite connection.
Old 06-23-2015, 09:23 AM   #8
Hmmm.... bclemens or Joshua Cavitt, you guys want to jump in on this one?
Old 06-23-2015, 02:26 PM   #9
Georgia Rally Coordinator
aceinspp's Avatar
When going to cable just remember to turn off the little button you pushed for the boost Not needed for cable. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 67
Old 06-24-2015, 12:55 AM   #10
For my '16 3171 the top position is sat and middle is catv. Must be different.
antenna
