Old 01-25-2015, 06:20 PM   #1
DnL
Tv-dvd problem
Help please. I'm thinking my problem is a loose wire(s) but I have no idea where to look. The TVs in the bedroom and outside stopped showing movies (DVDs) in color - only black and white. One day they were working just fine, and the next just black and white (both at the same time). TV reception is color - just the movies are black and white. Thanks in advance for your help.
DnL is offline   Reply With Quote
Old 01-26-2015, 03:36 PM   #2
GM
bclemens's Avatar
Movies are coming through the splitter via coax correct?
You may be getting interference from a channel closer to 3? What channel are you using 3 or 4? Might need to re-scan, check wiring connections. If you have the switch box you can change from channel 3 to channel 4 as well.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 01-26-2015, 05:15 PM   #3
DnL
bclemens, I need to apologize. After I posted this post I realized how badly I explained the problem and how much info I left out. And then I couldn’t figure out how to delete it so I just did a second post (Subj: “RCA (TV) splitter box location”. Here’s the whole story.
The antenna and park cable are coax. The DVDs from the entertainment center are RCA (yellow, red, and white).
I have a 2013 Forester 3011DS with a Magnadyne entertainment center in the dash and a Magnadyne VCS-10 switching center mounted inside the cabinetry under the main TV in the kitchen. Two of the three TVs (bedroom and external) stopped showing DVD movies in color – just black and white. The main TV still shows color movies, and all 3 show color TV programs. I’m thinking there might be a loose RCA connection somewhere, and since it happened to two TVs at the same time I’m thinking it might be at a splitter. I just don’t know where to look for the splitter.
Another forum member responded to my second post saying his splitter box is behind the main TV. So now I'm wondering, if I get the main TV down from its mount (not a swivel one) will there be easy access to what's behind it - like a hole in the bulkhead?
Thanks for all your help.
Old 01-26-2015, 05:23 PM   #4
Flybob's Avatar
Try turning Antenna amplifier off ( small push button on ant outlet jack)
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-27-2015, 01:25 PM   #5
GM
bclemens's Avatar
Originally Posted by DnL View Post
bclemens, I need to apologize. After I posted this post I realized how badly I explained the problem and how much info I left out. And then I couldnít figure out how to delete it so I just did a second post (Subj: ďRCA (TV) splitter box locationĒ. Hereís the whole story.
I have a 2013 Forester 3011DS with a Magnadyne entertainment center in the dash and a Magnadyne VCS-10 switching center mounted inside the cabinetry under the main TV in the kitchen. Two of the three TVs (bedroom and external) stopped showing DVD movies in color Ė just black and white. The main TV still shows color movies, and all 3 show color TV programs. Iím thinking there might be a loose RCA connection somewhere, and since it happened to two TVs at the same time Iím thinking it might be at a splitter. I just donít know where to look for the splitter.
First, you have to understand how the TV's are being fed.
The coax cable serves two purposes. It carries any over the air signal to each TV AND acts as the signal cable for satellite/cable/dvd.
The dash DVD feeds the switch box with red/white/yellow (RCA) cables. The MAIN TV in the kitchen is fed from a split RCA cable from the dash, or from RCA cables on the OUT side of the switch box. The box then converts that RCA cable signal to Coax and it is fed back into the coax stream (for bedroom and outside TV). So instead of the bedroom TV and outside TV being able to change inputs...it need sot be on channel 3 or channel 4 and then scan for channels to pick up the DVD signal that is now being sent over the coax cable. It will never be high-def based on that conversion.
Having said all that...if you bedroom and outside are being fed via RCA, then that is probably a dealer add and not a factory install.
Old 02-04-2015, 12:09 PM   #6
DnL
bclemens, thanks for the info. It makes the wiring make a bit more sense. As it turns out, the problem was a simple menu selection in the DVD setup menu. And, of course, no one knows how it got changed to begin with.
dvd
