It is in an entertainment center. Fixed mount. no clearance on the bottom. < 1 inch on top. It is not the same set up as the 2013 SunSeeker. There are no wood plugs. As you can see the bottom trim abuts the tv. I cans see two screws between the top trim and tv but they will be difficult to get to. The two screws that I see between the bottom upholstered trim and TV are almost impossible to access, let alone remove safely
