Old 05-20-2014, 08:29 PM   #1
smulrenin's Avatar
tv mount issue
I am not able to get my 32 inch toshiba off the mount. It is in a 2011 3121 Forester. There are no latches and it will not move upwards, downwards or forward.
smulrenin is offline   Reply With Quote
Old 05-21-2014, 11:28 PM   #2
GM
bclemens's Avatar
Entertainment center? Swing arm? We needs some pictures...
Or search for how to get the tv off when you have an entertainment center
or click here. How do you get to cable connection behind the Entertainment Center?
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-22-2014, 05:13 AM   #3
smulrenin's Avatar
It is in an entertainment center. Fixed mount. no clearance on the bottom. < 1 inch on top. It is not the same set up as the 2013 SunSeeker. There are no wood plugs. As you can see the bottom trim abuts the tv. I cans see two screws between the top trim and tv but they will be difficult to get to. The two screws that I see between the bottom upholstered trim and TV are almost impossible to access, let alone remove safely Click image for larger version
Name:	ImageUploadedByForest River Forums1400753562.530058.jpg
Old 05-22-2014, 10:46 AM   #4
GM
bclemens's Avatar
I'll have to run this by the line, I'm not in the office this week. First glance it doesn't look like one that we built...but then again my memory is not what it once was.
Old 05-22-2014, 11:57 AM   #5
smulrenin's Avatar
Thanks. I will wait to here from you. In the mean time maybe somebody else has seen this set up on their Forester of Sunseeker.
Steve
Old 05-23-2014, 01:57 PM   #6
Bus Driver
Deaver's Avatar
Hello smulrenin
I have a 2012 2651S with the same configuration as yours. Although I have never removed my TV, I have the two mounting screw arrangement top and bottom as you describe. I am planning on trying to remove my TV as I wish to access the area behind it for additional storage ie blankets etc.
I have looked at mine and surmised that the screws that you can see are probably attaching a mounting bracket that mounts to the "Vesa" holes on the rear of the TV. I will make a latching bracket for rear access in the near future.
It looks like a two person removal, One to remove the screws, second to catch the TV
Deaver is offline   Reply With Quote
Old 05-24-2014, 09:41 AM   #7
smulrenin's Avatar
I agree at least a two person job. I am hoping that only the top screws need to be removed. Good luck.
Old 05-29-2014, 09:54 AM   #8
smulrenin's Avatar
Was able to remove the TV off the bracket by unscrewing all four nearly hidden nuts. There was a fixed mount attatced to the four Vesa holes. Very difficut job. Took two people. I did not want to attempt trying to put this back together and still not have acsess to behind the tv. I therefore purchased a swing arm type mount. I was able to attatch it to a 22 by 15 sheet of 3/4 inch plywood. Now I have acsess to the back plus extra storage.
Old 06-05-2014, 09:30 AM   #9
Bus Driver
Deaver's Avatar
Sounds Great
Did you take pictures by chance?
Old 06-05-2014, 09:44 AM   #10
smulrenin's Avatar
No did not take pictures.. I will try this weekend.
mount, tv mount
