12-25-2015, 12:17 PM
Two Questions
Hi All,
I own a 2016 Forester 2301. I think I know the answer to 1. but just want to confirm, but need help on 2.
1) After driving there always seems to be water in the shower pan. I assume that the driving and bouncing causes water to splash up into the shower pan from the grey tank. I will experiment with the grey tank empty.
2) The grey tank indicator remains on "E". Bad sensor?
Thanks in advance.
Happy Holidays.
John
12-25-2015, 01:19 PM
Possibly bad sensor or something blocking sensor on inside, like t. paper. Maybe even bad connection at sensor or sensor board.
No, you should not have water from gray tank/shower drain line "splashing" back into pan. How much water are you talking about? If just a bit, possibly small amount left in shower head, draining as you move down the road. Possibly a small leak in skylight (if there is one) over shower.
Only way I can think of it backing up from the drain would be if gray tank was overfilled, leaving water in the drain line. Lot of drain lines don't have a p-trap, just a stright drop into drain line, then into tank.
Grumpy
12-25-2015, 02:02 PM
X2 what grumpy said
2015 sunseeker 3050s. 2007 saturn aura
12-25-2015, 05:59 PM
My 2301 doesn't splash water up into the shower, I don't know what's up with that. I did have a problem with my black tank flush, it had construction debris/sawdust in it. There's a possibility that you may have a blockage because the guys at the factory were in a hurry.
2015 Forester 2301 - Chevy
Skip & Deb
12-27-2015, 06:23 AM
If the grey tank on our model 3100 Sunseeker is full or nearly full, water will slosh out of the shower drain when I make turns. Our shower and both sinks have p-traps.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
12-27-2015, 08:12 AM
Grumpy
Shouldn't be any t. paper in gray tank.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
12-27-2015, 08:59 AM
John F, your right about that. I must have had a "senior moment".
Grumpy
12-27-2015, 11:59 AM
Thanks all,
There must be a p-trap in the shower drain. In fact I noticed after using the shower I can see water in the drain with an empty grey tank. The water in the p-trap splashes out into the pan when driving. I don't think it's that big a deal unless I'm missing something.
Thanks again
John
12-27-2015, 12:02 PM
Yes there is a P trap in the shower. Mine broke and I had to fix it. Naturally I was away and not home!
12-27-2015, 06:12 PM
This P trap (and others) should be on your "Don't Forget" list when you winterize your trailer!
12-27-2015, 06:33 PM
That wasn't what broke mine. Poor assembly and taking showers caused it it brake. Threads were stripped and broke off.
12-27-2015, 06:36 PM
Any way to stop the water from splashing out of the shower p-trap when driving?
12-27-2015, 07:22 PM
Put a wet wash cloth on top of the drain cover.
Bruce
12-27-2015, 07:41 PM
I wasn't referring to your break. I should have removed that part from your Quote. Sorry.
12-27-2015, 07:49 PM
Trip to hardware store for an old fashion drain plug. Use it when bathing GK's. I think 1-1/4"
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
12-27-2015, 07:50 PM
Excellent idea. Thank you
