10-20-2016, 12:03 PM
Underground winter storage, batteries, generator
Can anyone who stores their motorhome underground for the winter please let me know what you do since you can not run the generator on a regular basis and your battery is not hooked up to a trickle charger?
Thanks!
13STL
2017 Forester 3051S
Jill, Mark (and dogs Paco & Isabel)
10-20-2016, 02:49 PM
Do you have a battery disconnect switch?
I don't store mine underground but my batteries are still nearly fully charged after 4 months of storage by using the disconnect switch.
10-21-2016, 07:18 PM
Thanks for your reply. Yes, we have a disconnect. Do you have a generator? What do you do about that?
13STL
2017 Forester 3051S
10-21-2016, 09:24 PM
I don't own a motorhome, so no built in generator.
But I would assume that you'd treat like any generator by adding Stabil.
10-22-2016, 02:10 PM
what do you mean underground? Like in the basement of your house, dampness may be a problem
10-22-2016, 02:48 PM
Maybe like Cleveland,Ohio, Salt Mine Storage? Youroo!!
10-22-2016, 06:52 PM
Hello
We store our Sunseeker under ground in an old limestone mine. All I do before storing the MH is plug it in for a day or two before going to the mine. I measured the voltage and both house batteries were at 13.5 volts. Also check engine battery to make sure it is charged as well. Lastly I make sure all tires have proper air pressure.
When I park it in the mine I disconnect the engine battery and turn off house batteries with the switch. Have stored it for the past 4 years and when I pick it up in April everything is good. Mine temperature is 55 degrees year round.
10-22-2016, 07:45 PM
I was making reference to an underground limestone mine that is now used for storage. I am concerned about the dampness underground. We are trying to figure out if it would be better to store underground or cover the roof and keep it parked in our driveway.
13STL
2017 Forester 3051S
10-22-2016, 07:49 PM
Originally Posted by rhughsless
Hello
Thanks for your reply. I see you are in Butler, PA. Do you store at Toys Underground? That is where we were looking. We are in Saxonburg.
13STL
2017 Forester 3051S
10-22-2016, 07:59 PM
Yes that is where we go. Have been there since Toys bought it from US underground in 2012. Very nice people. If you store it don't forget to use damp rid. We use 3 tubs 1 in the bedroom 1 on the kitchen counter and the third one in front of the sofa.
Good luck.
Randy
10-23-2016, 05:49 AM
You read the battery while charging; that shows you that the charger is working but not the battery voltage. A full resting battery should read 12.65 to 12.7 volts. Resting means it must not be charging or discharging for a couple if hours ... then take your reading. If its not the sealed type battery, a hydrometer is the better than a voltmeter to measure for % of charge.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
10-23-2016, 06:50 AM
Being from SW Florida, underground storage is something we will never experience. Curious though, what do they charge?
10-23-2016, 07:01 AM
Normally between $350. - $450. for Oct - April.
13STL
2017 Forester 3051S
10-23-2016, 07:07 AM
Good luck.
Randy
Now that I put up my own 20x 36 carport what is the cost of using the mind?
10-23-2016, 07:10 AM
You never want to use the salt mine first everything goes down a elevator and what goes down never comes back up only people. Things get so much salt dust in it that when it hits open air it will rust away in a few weeks
10-23-2016, 07:22 AM
Dang. I'm paying 250 a MONTH for 40' covered (open front, not a garage) and that's a good price. 40' garage storage is another 60 a month. The upside is that it's a very secure place. 15' solid walls, video security all over, entrance is an overhead garage door operated by code. We jokingly call it Fort Knox.
10-23-2016, 08:32 AM
That sounds like a nice storage facility....and you don't have to worry about problems cause by dampness.
13STL
2017 Forester 3051S
10-23-2016, 02:12 PM
This is fascinating to me. Never thought about it before, but my wife says they do this in WV in their mines too. Our humidity levels here in the summer reach 90% plus. What are the temps and humidity in those mines? Do you have frame/steel component rust issues?
David and Vicki
19-month-old English Springer Spaniel "Sadie"
2019 Silverado LTZ Duramax
2023 GDRV Reflection 150 226RK
10-23-2016, 02:43 PM
They say the temp stays around 55 degrees and the humidity up to 65 percent.
13STL
2017 Forester 3051S
10-23-2016, 02:59 PM
In our world, that's not so bad.
David and Vicki
