Old 01-14-2015, 06:40 PM   #11
We had to take our Avenger back 2 times. because we could get the tv to do anything. the 1st time they had to replace the antennae because it wouldn't unfold all the way, the 2nd time to connect the antennae into the entertainment center and the tv and DVD player together. it wasn't attached together when we bought it.
not sure if was dealer error or Factory install gone wrong
ValMelton is offline   Reply With Quote
Old 01-14-2015, 08:42 PM   #12
It looks like we will have someone take a look at it. Thank you for the help. Greatly appreciated! I will also look into the Magnadyne manual but I suspect that something was never hooked up.
joyfulmajoya is offline   Reply With Quote
Old 01-14-2015, 09:44 PM   #13
Did you set the emergency brake?
coldj is offline   Reply With Quote
Old 01-15-2015, 01:28 PM   #14
bclemens's Avatar
Won't matter. the emergency brake only locks out the dash screen...not the rear output.
I'm guessing
A. something is not hooked up or
B. This unit has a switch box and it was not wired directly. I have a thread on this as well. If you look at the back of the TV you should see a Red/White?yellow cable INOT the AV1 hook up. (there is also an audio out, but thats another topic). If those are not there, then you may have a switch box. Those cables will go into the switch box and then to the TV via coax. In that case you have to change to "scan for channels" via "cable". A direct connection to AV1 is always better for image quality etc.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 01-27-2015, 10:47 PM   #15
We do have the red, white and yellow cables hooked to the back of TV. They appear to lead into the cabinet above the entrance door.
