Old 06-03-2016, 09:41 AM   #11
Commercial Member
Here is a blog post on valve extender hoses.
And here is a thread answering the question you asked (simple search on valve extender hose found it)
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 06-03-2016, 10:34 AM   #12
Sagecoachdriver's Avatar
Originally Posted by GL1800Rider View Post
Like Sagecoachdriver, I use these from Pacific Duallies bought on Amazon at $19.71 for the pair and so far with about 3500 miles no issues.
http://www.amazon.com/Pacific-Dualie...ilpage_o09_s00
Thanks GL1800Rider, that's what I bought, I got them from Amazon for $20.41 with tax on Sept 19, 2015. Mine are working fine. I did have an issue with the wire spring and Benagi here on the forum showed me how he did his and it worked better.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 06-03-2016, 09:58 PM   #13
When I first got my 2861DS 3 months ago, I had to remove the wheel covers to reach the inner tires. One had a plastic extender. The other one did not. It was a pain to add air to the inside tires. I replaced all 6 valve stems with brass metal stems from TireMan. Also added internal mounted TPMS.
You might want to consider replacing the valve stems with metal ones.
ADOR is offline   Reply With Quote
Old 06-04-2016, 12:07 AM   #14
benagi's Avatar
X2
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 06-04-2016, 09:52 AM   #15
Commercial Member
Just be sure the outer end of the extender hoses are firmly tied down. You do not want them flopping around. Also they should be attaching to metal bolt in valve stems and definitely not rubber snap-in valves as vibration from small amounts of movement of the hose and TPMS sensor can fatigue the low pressure rubber valve stems.
