06-01-2016, 06:48 PM
valve extenders on inner dual
we have 2016 2861ds ford that we bought from cw a week ago and are having no luck adding or checking the air pressure. I s this extender installed at the ford, forestriver,or the dealer. I guess i need to buy some better ones.
06-01-2016, 07:04 PM
Most duals,if you clock the wheels where the stems are 180 degrees out, you will be able to use a double headed air chuck..Still a PITA,but doable.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
06-02-2016, 12:21 AM
When I had this problem I found removing both the flow-through valve cap and the wheel simulator (that's what they call those dulley "hubcaps") made it easier to check and add air.
I solved all those problems once and for all by having some high quality solid metal extended stems installed on every wheel.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
06-02-2016, 01:40 AM
Congratulations on the new Forester!
Do a search in the Forester and Sunseeker Forums as we discussed this back last fall when many of us first got ours. Many have done what CreativePart has done and gone with the metal dually extensions, it's the best, permanent and costly. Can be purchased from Borg tire supply (YourTireSupplyShop.com) Duallyvalve Kits for Class C - Ford GMC 16-19.5" or the Tireman in Ridgecrest,CA ( Tire-Man: Home Page . Both have online sales.
I'm changing mine when I replace the tires in a few years to avoid paying the $100-$250 for mounting and rebalancing.
In the meantime, I have gone with a flexible wire mesh covered inner dually stem from Pacific Duallies.
Did you know that the steel wheel liners come off like hub caps with a screw driver or small crow bar?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
06-02-2016, 04:28 AM
Wait till next year...
Went thru the braided and metal extenders. Can't say I liked the braided and the metal extenders were to heavy ended up going back to the Air flex with the solid rubber oval stabilizers and haven't lost any significant air since. I use the stabilizers on all 6 tires. As for not being able to read pressure if FR is still using AirFlexx check that the center pin is there and trim the end so your chuck is actually activating the inside Schrader valve. For more info do a search for AirFlexx
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
06-02-2016, 01:38 PM
Dual Wheel vale extenders?
I had the same issue with adding air on my Forest River Sunseeker 2500.
I did the research and found that the DuallyValve is the hot set up, as mentioned above!
I opted for the chrome extenders and I had a local truck tire shop de-mount and install the valve extenders.
It made a day and night difference and I was able to reinstall my wheel covers.
Now it's very easy to check and add air, with the valve extenders exposed and it's also easy to install tire pressure monitoring systems!
Longhunter
Northern Illinois
2015 Sunseeker 2300
06-02-2016, 02:24 PM
Buy some any auto parts or truck stop.
06-02-2016, 03:49 PM
valve extenders
When I picked up my Forester a year and a half ago my first upgrade was a trip to a local tire store and have regular brass truck tire rigid extenders installed. Cost me $84.00 installed and worth every penny and my monitors are stable.
06-03-2016, 09:02 AM
Valve extenders?
I did all six tires with the extended valve stems from Duallyvalves.
That allowed me to re-install my wheel covers. Then I could re-install the tire pressure monitors that I couldn't use with the wheel covers on.
Longhunter
Northern Illinois
2015 Sunseeker 2300
06-03-2016, 09:30 AM
Citrus County, Fl.
Like Sagecoachdriver, I use these from Pacific Duallies bought on Amazon at $19.71 for the pair and so far with about 3500 miles no issues.
http://www.amazon.com/Pacific-Dualie...ilpage_o09_s00
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
06-03-2016, 09:41 AM
Commercial Member
Here is a blog post on valve extender hoses.
And here is a thread answering the question you asked (simple search on valve extender hose found it)
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
06-03-2016, 10:34 AM
Originally Posted by GL1800Rider
Thanks GL1800Rider, that's what I bought, I got them from Amazon for $20.41 with tax on Sept 19, 2015. Mine are working fine. I did have an issue with the wire spring and Benagi here on the forum showed me how he did his and it worked better.
06-03-2016, 09:58 PM
When I first got my 2861DS 3 months ago, I had to remove the wheel covers to reach the inner tires. One had a plastic extender. The other one did not. It was a pain to add air to the inside tires. I replaced all 6 valve stems with brass metal stems from TireMan. Also added internal mounted TPMS.
You might want to consider replacing the valve stems with metal ones.
06-04-2016, 12:07 AM
X2
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
06-04-2016, 09:52 AM
Commercial Member
Just be sure the outer end of the extender hoses are firmly tied down. You do not want them flopping around. Also they should be attaching to metal bolt in valve stems and definitely not rubber snap-in valves as vibration from small amounts of movement of the hose and TPMS sensor can fatigue the low pressure rubber valve stems.
