Old 03-07-2015, 08:45 PM   #11
Boso's Avatar
Had problem with air bag valve not sticking out far enough to fill with air had to buy another chuck with air pin sticking out further but no problem with tires
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 03-08-2015, 03:07 AM   #12
2012 Solera
Been a few years now, but my memory is that I used a Dremel tool to trim our Air Flex extension outers (last few threads) to get them to work. The Air Flex threads are plastic or nylon - easy to trim. Can't comment on other brands of extensions. Also (as noted in the earlier threads linked above) someone else solved the problem by removing the extensions and trimming the other end -so they would screw further unto the valves, again effectively shortening the exterior and exposing more of the inner "stem".
JLeising
2012 Solera "S"
Calif SF Bay Area
