Old 01-28-2015, 04:20 PM   #1
Valve stem extensions
Does anyone have problem putting air in the outside rear tires on their Forester. I thought it may be the extension, but I swapped them and same problem. Have come to the conclusion that it may be the bent valve stem, but after removing the extension I can check the tire and air it up easily. But I must remove the chrome covers to check the tires. Any comments would be appreciated.
5hfarms is offline   Reply With Quote
Old 01-28-2015, 05:46 PM   #2
Average Joe
MrJoe's Avatar
Mine are messed up. I found that certain chucks just don't work with them. Also, they bleed air unless I loosen the cap. It won't take air with a loose cap, but doesn't leak. Crazy.... It's on my to-do list.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 01-28-2015, 06:04 PM   #3
dan-nickie's Avatar
On my class c, I had to loosen the extender a little to get it to take air.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 01-28-2015, 06:38 PM   #4
2012 Solera
If it uses the same Air-Flexx valve stem extensions as the Solera, lots of threads and posts on this issue - e.g. can't add air to inner rear tires. Center part of the extension is too short to press the valve stem in. Some have found air chucks and gauges with long enough "pressers" to work, some (myself included) have trimmed the outside of the extensions to expose more of the center (either end).
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 01-28-2015, 10:42 PM   #5
The extension seems long enough, but does not accept air and can not make a good connection to check air pressure
Old 01-29-2015, 02:53 AM   #6
2012 Solera
Extension itself was quite long enough on our Solera. The piece inside the extension which activates the tire valve when adding air or checking pressure was too short so it never opened the tire valve, thus prohibiting checking the pressure or adding air. Corrected by cutting several threads off the extension, exposing more of the inner "actuator".
Again, suggest you check the other threads on this issue - see link in my post above.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 01-29-2015, 04:49 PM   #7
GM
bclemens's Avatar
OP stated it was the "outside rear" tire. On a Ford that is an angled metal valve. I'd rather leave it straight and everyone use a reverse chuck.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 01-29-2015, 08:07 PM   #8
These are the angled valve stems that came with it. I used a little longer extension and a different brand. These seem to seat a little better and work better. I see what you all are saying about the valve core not pushing deep enough to allow air into the valve stem. Thanks for all the help.
Old 01-29-2015, 08:43 PM   #9
I took my Forester into a tire shop down here and had brass truck valves installed into the rims and tomorrow I will be receiving a set of wheel simulators so that I won't have to take the hub caps off to check the air pressure.
poppytoymaker is offline   Reply With Quote
Old 03-07-2015, 06:04 PM   #10
How do you cut extender threads shorter to expose more of the the actuator. Having same problem of not being able to inflate after Campingworld installed flex tire valve extenders.
elabrain is offline   Reply With Quote
