Old 01-05-2014, 09:01 AM   #1
Frank & Eve's Avatar
Water filter.
Does anyone know how often the inline water filter is suppose to be replaced? We removed ours for winterization still looks new. Tks
Frank & Eve is offline   Reply With Quote
Old 01-05-2014, 09:25 AM   #2
iceblaze580's Avatar
I would do it once a year or when it starts looking dirty
iceblaze580 is offline   Reply With Quote
Old 01-05-2014, 09:29 AM   #3
DDC
DDC's Avatar
I remove it in the fall for winter and put a new one in the spring, for what they cost it's just not worth the risk.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 01-05-2014, 09:37 AM   #4
Ford Idaho's Avatar
This!
Ya got the old used one out why would you want to but it back?
Old 01-05-2014, 11:36 AM   #5
Originally Posted by Ford Idaho View Post
This!
Because I'm thrifty and if the other one still looks new why not use it again?
Old 01-05-2014, 11:46 AM   #6
WFD
We use an external water filter, and when we will be parked at home for a couple weeks or more between trips and no water will be used or flow through it, the instructions say to store it in the fridge. I assume that is to prevent bacterial growth in the filter while it sits in the heat with no fresh water flow. What do you do with your inline ones? Some are a real pain to access, not so bad to do once or twice a year, but between trips?
Rick
WFD is offline   Reply With Quote
Old 01-05-2014, 11:46 AM   #7
Ford Idaho's Avatar
Because of the material the filter has trapped.
Under the right conditions mold may start to form in the folds.
Being "thrifty" is fine playing with potential health issues for a couple of bucks is not.
It is your water supply treat it like YOU would drink it.
Good luck.
Old 01-05-2014, 12:14 PM   #8
Oakman's Avatar
I believe the original filter that comes with the trailer is good for 10,000 gallons. However, I replace mine annually or anytime it becomes discolored.
I'm no expert but it seems to me that with the moisture in the filter it would become a growing medium for mold or other nasty things as it dried out. I wouldn't reuse one.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 01-05-2014, 12:44 PM   #9
Alrigjty then didn't think it through about the bacteria and mold you all have convinced me! It will be replaced See how good this forum
is !!
Old 01-05-2014, 12:51 PM   #10
GlacierGus's Avatar
Originally Posted by ddc View Post
i remove it in the fall for winter and put a new one in the spring, for what they cost it's just not worth the risk.
x3.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 01-05-2014, 01:18 PM   #11
I hope my Doctor isn't (Thrifity) and reuse the (Needle),they still look (New) also! Replace the filter! Youroo!!
Old 01-05-2014, 03:55 PM   #12
ourflat's Avatar
Replace once a year! The OEM filter isn't cheap....
Frank
ourflat is offline   Reply With Quote
Old 01-05-2014, 04:34 PM   #13
Come on now I hardly think there is any comparison here. The only harm would be to myself. But it will be replaced
Old 01-06-2014, 08:02 AM   #14
Not to hijack, but hardly worth a thread of its own, is there a way I don't know about to remove that cannister without water going everywhere?
thatguy is offline   Reply With Quote
Old 01-06-2014, 09:05 AM   #15
Witch Doctor's Avatar
you would need to put a pan under it, no matter how careful you are it will spill depending on the units location of the filter.
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-06-2014, 09:11 AM   #16
Oakman's Avatar
Don't lose the rubber "O" ring in the top of the filter housing when you empty it.
Sent from my NX008HD8G using Forest River Forums mobile app
Bob and Joyce
ATU Local 788
Old 01-06-2014, 09:38 AM   #17
If you depressurize the system and open the main headers drains first you will minimize any spillage. There is also a compartment drain plug right under the filter (at least on my 3120) that you can open to help control any spillage. Little drain pan as posted will also work well.
ATVer is offline   Reply With Quote
