Old 03-09-2012, 09:08 PM   #1
Water Filter Replacement?
I have no paperwork as to which filter/size/etc. will fit the factory installed water filter opening. Looks like a few brands "may" fit but unsure which is an exact fit. I disposed of the dirty filter this past fall and should have noted the size/brand.
Can someone comment on which filter works in the factory holder?
mwebber78 is offline   Reply With Quote
Old 03-09-2012, 09:57 PM   #2
TURBS's Avatar
Any hardware store carries the water filter
The whole house filter assy they carry is the same that's in your camper
Old 04-22-2012, 05:43 PM   #3
I am in the same boat. The whole house filter in my house is much larger than the filter in my camper though. I found a 10" on Amazon that looked the same. I might just try that one.
2012 Jayco 33 RLDS
2004 Chevrolet Avalanche 2500
2007 TBSS AWD
Hybrid21SS is offline   Reply With Quote
Old 04-22-2012, 05:46 PM   #4
I buy mine at Lowes.
Old 04-22-2012, 05:50 PM   #5
camping
tentcamper1's Avatar
x2
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 04-22-2012, 05:58 PM   #6
Fire Instructor's Avatar
They are a standard "size", it's the microns that vary.
You'll find a wide degree of differing opinion on what micron size to use, this is what really determines the quality of the filtering. I'm good about knowing where my water is coming from, so I generally use one that isn't as "tight" as other might use.
Keep in mind that this will affect water pressure, as the filter produces a pressure drop. A filter for a house on city water can have 100+ PSI pressure pushing the water through, though generally, hosehold pressurre is regulated to 50+/-PSI. The little pumps in an RV push nowhere near that kind of pressure.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 04-22-2012, 06:07 PM   #7
Triguy's Avatar
My water filter is a Water Pur CCI-10-CLW clear Water Filter Housing and uses a CCI-10-C filter. Everything in standard 10" length will work in the housing. It needs to have holes in the bottom and top to fit in the housing.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-22-2012, 06:08 PM   #8
Wanna Be Camper
SaskCampers's Avatar
A Rainfresh CF 2 carbon filter fits perfect
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 04-22-2012, 06:09 PM   #9
I'm replacing the original 4008 Surflow which is noisy and runs every 10-15 minutes (no leaks) with a new revolution wich is rated at 55 psi so I hope to have a little better shower pressure with the filter..
2012 Jayco 33 RLDS
2007 TBSS AWD
Old 04-22-2012, 06:11 PM   #10
Big Dawg's Avatar
I bought two at Menards, they include the charcoal for filtering.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
