Old 05-06-2019, 05:48 PM   #1
Water in backup camera.
The RVS Systems backup camera in my 2019 Forrester 2291SF is partially full of water.
The service center where I could get the work done is a 6 hour drive. Has anybody had experience with this camera. There is a YouTube video but it as for a slightly different camera that the front comes off with screws. This camera appears to be bonded one piece.
Mstanlake is offline   Reply With Quote
Old 05-07-2019, 11:35 AM   #2
I had the same problem with two RVS cameras, the original and the one replaced by the dealer under warranty. RVS told me they wouldn't cover the 2nd one so I'm looking for a different brand replacement camera.
DW, DD (sometimes), DS (sometimes), 2 camping poodles
2017 Forester 3011DS
mbutts is offline   Reply With Quote
Old 05-07-2019, 10:08 PM   #3
Tadi Brothers say they have one that will adapt to the current wiring. I am on my second RVS. So far it is working, but night vision sure needs improvement.
AbdRahim is offline   Reply With Quote
Old 05-25-2019, 09:25 AM   #4
Same issue how did you replace your camera?
Hey I have the same problem and need to replace my camera. When I pull the wire out there is no connector that I can find by the time I run out of slack. Did you have to remove something to gain access to the connector when you replaced yours?
Thanks, Jake
JakeCowls is offline   Reply With Quote
Old 05-25-2019, 09:35 AM   #5
RVS wouldn't send me a replacement and told me I needed to go to my useless dealer for the repair. The dealer's tech said he had to remove the inside crown moulding to get to the connector.
The new camera had the same problem within a month or two. RVS wouldn't allow a second replacement.
Old 05-25-2019, 11:59 AM   #6
2012 Solera
RVS modification
I have not had the “water in the camera” failure, but have recently done some work on the RVS camera/multiplexer/monitor system on our 2012 Solera.
The system stopped working- monitor just reported “no signal”. Eventually determined corrosion on the input connector solder joints in the multiplexer was the problem. Alcohol scrub with an old toothbrush fixed. However, wife said she “hated” the quality of the image, and said I should do more...
Experimented with an alternate monitor plugged into the multiplexer’s RCA monitor output - marginal improvement, image still pretty “washed out”. “Bench tested” with an alternate camera - I added an RCA camera input by soldering a female RCA connector to an input terminal on the multiplexer (see attached image showing the multiplexer pinout) (I id’d the ground terminal by ohm meter and counted pins to the video terminal) connecting to the video and ground terminals. This worked and seemed to improve the image significantly.
Camera I used:
https://www.amazon.com/NOAUKA-Waterp...%2C307&sr=8-10
As what I wanted was a “rear view mirror replacement “ and as I don’t tow, I installed a new camera on the license plate mount and routed its cable under the MH - found there is a cable input opening (closed by a wire tie) under the driver’s seat - routed the cable through that and under interior trim to the multiplexer. I left the original camera in place and connected (the multiplexer on our MH has three ports, only one was originally in use). Should I tow some day, I can switch to the original “high mounted” camera.
I also added a third camera on the passenger side of the MH - used the third multiplexer input, similarly converting it for RCA input. The MH has a significant blind spot should I be at an intersection where a road enters from about a 45 degree angle on the passenger side. Have depended on my passenger looking for me in these situations- believe I can now switch to my new “side view” camera should my passenger be asleep.
If I were to have to replace the original camera, I would probably cut the existing cable at the camera, id the video and ground wires (color code?), and install a simple video only standard RCA connector camera.
Of note, with my current set-up, using the original RVS video+audio camera, when in reverse and viewing the “new” camera, the audio works!
FYI - hope some of the information is useful -
Jim
ID:	205442   Click image for larger version
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 05-25-2019, 05:45 PM   #7
I haven’t tackled it yet, I am hoping a few weeks of warm weather will dry it out
Old 05-25-2019, 06:31 PM   #8
2012 Solera
Never tried it with a backup camera, but a small hole in the bottom of a headlight that fogs up can help. Obviously, out of the field of view, as much as possible. Once not sealed, in my experience, best to let it breathe...
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 05-25-2019, 06:39 PM   #9
Totally agree, as soon as it gets out of warranty I will be drilling a small hole
Mike
Old 05-26-2019, 03:25 AM   #10
Corrosion on circuit board
So I took the camera apart and cleaned out the moisture. I found some corrosion on the circuit board that the camera is on, but I cleaned it with some IPA and it seems to be working okay now. I would warn against putting a hole in the camera as it would expose the circuit board to additional moisture. I resealed it with some silicon. Lets see how much longer it lasts. I will probably just order a new camera. I found a RVS one on Amazon for about $100. I just need to find how to access the connector so I can replace it. Thanks
water
