You're correct, it's the check valve. Pretty common problem.
First, shut off city water, turn on your water pump and run FW tank water through it for a minute or two. Then go back to city water.
The check valves often get something in them or get mis-aligned.
If the above doesn't work, you'll need to replace the valve.
2011 Traverse LT, 3.6L, FWD
