Old 10-23-2018, 10:49 PM   #1
Water leaking from Air Conditioner
2018 3011DS. Heavy rain - water is leaking from the AC/heat pump. Where do I plug this leak? Can I do it from inside? Looks like it will rain for a couple more days.
Thanks in advance.
Dave Allen
Psadave46 is offline   Reply With Quote
Old 10-24-2018, 07:24 AM   #2
Duckogram's Avatar
Well Psadave46 your post does not contain much info (clues) such as A/C model and where it is leaking from so all I can do is guess that you have the usual Atwood AirCommand AC1511 Heat Pump issue.
If that is the case I thought I had the same problem. However, it is a design issue and it is being addressed by Dometic. So for now, clean the filter and the “leak” will stop for a few days. More info is available here: AirCommand Water Penetration
ILB ( | )
Old 10-24-2018, 08:10 AM   #3
There is a gasket between the AC unit and the roof. Sometimes just tightening it up solves the issue. You do not want to over tighten it. Sometimes that gasket needs to be replace as it gets completely compressed.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 10-24-2018, 04:29 PM   #4
Thanks to all - issue resolved
I removed the inside grill and tightened the four mounting bolts. I only tightened them a little.
Thanks again,
Dave
Old 10-26-2018, 09:01 AM   #5
That might be the fix. We will hope so.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
air conditioner, leak, water, water leak
