Old 01-24-2016, 12:21 AM   #1
Water leaking into basement areas
Hi, has anyone had this issue? The RV was parked on a flat , level surface. The basement doors were securely closed and locked yet I discovered a large pool of water in each one. We had rain but no wind. I wiped them out but two days later ( no new rain ) it reappeared. Help!!!
2015 Forester
Auntielo1 is offline   Reply With Quote
Old 01-24-2016, 03:00 AM   #2
Witch Doctor's Avatar
Have any water lines passing through those areas? Could have a leak still leaking with no rain as you said. Also might be condensation this time of year.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 01-24-2016, 11:46 AM   #3
Tinkerer and Putterer
Our 2013 rig had something on the doors from the manufacturing process that caused the seals to stick to the frames. They tore slightly when I first opened them causing leaks. Replacing the seals fixed ours up.
HappyGuy is offline   Reply With Quote
Old 01-24-2016, 05:12 PM   #4
MNtraveler's Avatar
Clean water or road water?
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 01-24-2016, 05:16 PM   #5
It's outside/rain water. It's on both sides of basement. There's no plumbing back there.
Old 01-24-2016, 05:51 PM   #6
We just took our 2016 in for a leak coming from the shower.
Recce4 is offline   Reply With Quote
Old 01-24-2016, 05:56 PM   #7
I don't get it. It seems there's a lot of issues with the Forester. I waited two years to be able to afford to pay cash for mine. I walked thru them over a dozen times and looked online for any outstanding issues but not until I found this forum were my worst fears confirmed.
Old 01-24-2016, 07:11 PM   #8
All motorhomes have little issues thanks to the fact that they are rolling houses built with an eye towards weight reduction and cost. You just can't get away from them regardless of brand. I would run my hand over the door gaskets and look for cracks or tears. I would also look to see where the seam is for hte gasket. I have seen some installed incorrectly with the seam not on the bottom. I would hope that this was not the case but you never know...
Old 01-25-2016, 05:12 PM   #9
Future Buyer
Check the door frame
I had a similar problem with a non-FR trailer. The problem was that the door frame did not seal to the outside trailer walls. Dealer caulked around the outer door frame and problem went away.
IdahoBob is offline   Reply With Quote
Old 01-26-2016, 08:05 AM   #10
Wolverine 1945's Avatar
Is it possible the Wheel Wells are leaking ???
Wolverine 1945 is offline   Reply With Quote
leak, water, water leak
