Old 09-06-2018, 08:56 AM   #1
Water on floor
We have a 2016 Forester 2401W. Recently water has started to accumulate on floor at the base of the bathroom door near the refrigerator. I took off access panel under fridge and didn't see any moisture there near water heater. I have a feeling it is a condensation issue not a leak. Does Dometic fridge have a drain line?
jenunn01 is offline   Reply With Quote
Old 09-06-2018, 09:00 AM   #2
cavie's Avatar
Yes, remove the panel outside behind the fridge. Be sure it is not blocked.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 09-06-2018, 09:54 AM   #3
Fridge drain line is clear. Gotta be a leak under bathroom sink but don't see a way to get to it with built in sink in way.
Old 09-06-2018, 10:55 AM   #4
cavie's Avatar
Is the water coming from around the hose or inside it? can you see the hose inside the rig? Shower/tub drain may be leaking. Run some water and see where it goes. They have been known to seperate.
Old 09-06-2018, 11:29 AM   #5
Water seeping out right where bathroom sink cabinet ends at door . Is accumulating at door frame and just in front of right side of fridge on. I have tried disconnecting city water but didn't help.
floor, forester, water
