Old 07-07-2019, 09:11 PM   #1
Water Pressure
I have a ndw Sunseeker 3050S. On both city water and with the pump, the water pressure is fine in the shower. But in the sinks, especially in the kitchen, it takes a couple minutes to fill up an ice cube tray. Which isn't a bad way to fill an ice cube tray, but that isn't what i want to do most of the time.
Is there a way to adjust this?
Mark Haffner
2019 Sunseeker 3050 SE
(30' with one long slideout, Ford E450 chassis)
Parkfreeon6th is offline   Reply With Quote
Old 07-07-2019, 09:17 PM   #2
PPST Wannabe
kenandterry's Avatar
Remove the diffuser on the end of the taps. You may find they tend to clog on occasion from crud in the water systems.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-07-2019, 11:10 PM   #3
bikendan's Avatar
Yep, remove the aerator on the faucet. Usually is construction debris.
Equalizer WDH
Old 07-08-2019, 03:37 AM   #4
You donít usually need to remove the entire aerator. Most aerators have a tiny black o-ring inside of them ó this is the restrictor. Use a razor blade to separate the pieces of aerator encapsulating the o-ring, pop the o-ring out, then snap the pieces you took apart back into place.
Bruce
Old 07-08-2019, 06:11 AM   #5
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
We had a very similar problem with our Cardinal, but we have one of those faucets where the spray head comes out and can be more flexible. When I looked under the cabinet, I found the weight which pulls it back down was causing a significant "kink" in the flexible hose. I loosened the screws and moved it about 4 inches up - and the problem was solved immediately and hasn't returned.
If it's not debris - you might check that out if you have the flex-head on the faucet.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 121
rjshiflet is offline   Reply With Quote
pressure, sunseeker, water
