Originally Posted by blevinseve
Still looking. Beside the water filter are 2 water lines one red one blue. The blue one has a shut off valve. I'm assuming that this shut off valve allows me to remove that filter?
No, I think that is for your fresh water tank drain. At least that is what mine is for.
On the water pump, you sure it wasn't anywhere behind the panel with the door? The door is more for the access for the water filter but the pump can be more rearward. You can also check near where your water tank is and under the kitchen cabinets but I believe FR places the pump outside storage compartment partly because of the noise and partly because of service access.
