Old 09-01-2015, 12:55 PM   #1
water pump cycles when no water demand
My water pump cycles intermittently when no water is being used. It is not frequent and i have been assuming that it is just maintaining pressure, but i read somewhere today that it should not cycle at all if no water is being used. Should I be concerned that I have a water leak?
Thank you
2016 Forester 3051SF
MMulcahy is offline   Reply With Quote
Old 09-01-2015, 01:06 PM   #2
ourflat's Avatar
Your water pump should not cycle unless there is a demand against it! You might check for a leaks that is causing the pump to see a demand and turn on. A leaky toilet or a water line leaking somewhere...
Frank
KM4FVI
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 09-01-2015, 01:43 PM   #3
KennyGolub's Avatar
Mine did that and it was a water leak hidden behind the water controls panel. If I left it on long enough, eventually I would see water start to pool on the bottom of the water bay.
Ken & Laurie
Retired Cleveland CPD
2019 Entegra Aspire 44W
2018 Jeep Wrangler Unlimited
KennyGolub is offline   Reply With Quote
Old 09-01-2015, 01:49 PM   #4
Some time the one way valve in the pump will leak back into the fresh water tank as well.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-01-2015, 01:57 PM   #5
Georgia Rally Coordinator
aceinspp's Avatar
Frank
KM4FVI
X 2 Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 38
Old 09-01-2015, 01:59 PM   #6
mud yapster's Avatar
Yep better check for a leak. Pump won't come on unless it's loosing pressure so you have a leak somewhere.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-01-2015, 06:43 PM   #7
can't find leak
It occurs to me that maybe the ice maker is causing the pump to run. I got the RV out of storage and looked under the frig, sink, and bed and can't find any water. I also went under the rig but see now water seepage. If something is behind an area that i can't get to I have no idea if i'm leaking but am not find any water inside the rig.
When i got it out of storage i turned the pump on (thinking that if i had a leak the pump would immediately come on to refill what leaked while in storage, 3 days now). The pump did not come on except for a split second cycle when i turned on the power.
Is this wishful thinking?
Old 09-01-2015, 06:45 PM   #8
can't find leak
i need better proof-reading. I can find NO water under the rig or inside.
Old 09-02-2015, 09:18 AM   #9
I have a 3051 like you. My water pump does come on intermittently to refill the ice maker. That is if I am plugged in to shore power or running the generator. As I understand, the ice maker will not make ice if boon docking.
Rocket City Gary is offline   Reply With Quote
Old 09-02-2015, 09:37 AM   #10
Thanks to all who responded. this forum is fantastic for newbies like me. I"m going to continue watching for a leak but hope for now that it is the icemaker operation i hear.
pump, water, water pump
