Water pump issue?
4 year old rig.
Pump is a Shurflo 4008-101-A65 (pretty common I think).
Went to turn it on the other day...nothing. Check wires, breakers and fuses. Fuse on the pump looked good...removed it and put it back in. Tried it again- pump works ok. Seems like just a glitch. Now I did have the pump once turn off, I believe the thermal switch sensed the water was too hot and went off for about 30 minutes. Then worked good again.
I have since fixed that issue by attaching an adjustable thermostat to the hot water heater and turned it down.
Now I know these Shurflo pumps are usually pretty solid and last for years...I wonder if I should put out the $60 and get a backup. Hate to hurt a trip of dry camping with a bad water pump and no means to fix it.
Anyone keep a spare on hand?
(probably answered my own question and will get another unit but looking for feedback)
"If you are going through hell..keep going"
W. Churchill
