Old 09-16-2016, 02:24 PM   #1
Water runs off roof into the cab
We have a 2014 27 foot Forester MH.
Our only problem, that I am asking for some help on is when it is raining, you canít get in or out of the driver or passenger side doors without rain draining off the motor home rain gutters onto the inside of the doors where the electrical components that control the windows and door locking mechanism are. Water and electricity do not mix. Any ideas on how to prevent this from happening.
rhamilton is offline   Reply With Quote
Old 09-16-2016, 04:21 PM   #2
Rvrphdawg's Avatar
Same problem in my 2016 3011 DS. Tried aftermarket gutter extensions. They didn't fit. Even if they had, water would still drip inside the door. I noticed that the 2017 model has a gutter extension!
Forester 3011DS
Rvrphdawg is offline   Reply With Quote
Old 09-16-2016, 08:40 PM   #3
kdwallin's Avatar
Agree. Same problem in my 2017 2401W Forester MBS. Any ideas for after market solutions?
Kelly & Mary Beth
2017 Forester MBS 2401W
Kelly and MB
2017 Forester MBS 2401W Class C motorhome
kdwallin is offline   Reply With Quote
Old 09-17-2016, 07:34 AM   #4
Chief tinkerer
Gidyupgo's Avatar
Common. The extensions move it out a few inches which aligns with the fully open door. Haven't seen anything other than someone put a short section of hose over the extension to move it a couple of more inches. I just try to minimize the time I keave leave it open.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 09-17-2016, 12:34 PM   #5
This is a pretty common complaint with about any Class C. Even the AC condensation will run off. The rain will also enter the forward bunk windows if they are open. I have been considering putting diverters on the roof edge to run the water behind the doors.
There is also self adhesive guttering kits available. They are a bit pricey and not sure how well they would adhere or if they could handle a downpour.
Hopefully one of our ingenious members has the answer.
PenJoe is offline   Reply With Quote
Old 09-17-2016, 01:08 PM   #6
oldsmasma's Avatar
If it is really pouring we use the cabin door rather than the front doors.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
oldsmasma is offline   Reply With Quote
Old 09-17-2016, 01:13 PM   #7
GM
bclemens's Avatar
Problem is, unless the gutter is 48"...there's no good solution. We tried short extension, long extension, no extension in the front (just the rear) and ALL of them fail depending on the amount of rain you get.
One would work perfectly, until the rain intensity changed. In a hard rain one worked better than the other, but it was the opposite in a soft rain.
We started researched a 2-way gutter....but the way the the two ends had to come together and slope, it didn't look that good, or appear to seal that well. Might go back to the drawing board.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 09-17-2016, 01:15 PM   #8
PPST Wannabe
kenandterry's Avatar
If it wasn't for the design of C class units where they put a house on top of a Chevrolet, or Ford, or whatever van chassis, you wouldn't have doors immediately beside the driver and passenger seats.
A class units typically have just one house door.
For the times it's happening, just exit from the house door. And....if you have an electric awning, you can put that out to stay dry when leaving that way.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-17-2016, 02:04 PM   #9
mkekflyers's Avatar
Looks to be the nature of the beast, my '08 3100 had short extensions and they hit the inside of the door right ahead of the switches, my '16 3050s has longer extensions and they are a perfect hit on the switches...just have to remember to use the house door or park uphill...
2018 Georgetown 378 XL
2012 Ford Edge TOAD
Blue Ox & RVIBrake
2014 - 37; 2015 - 58; 2016 - 64;
2017 - 93, 2018 - 224, 2019 - kinda living in her...
mkekflyers is offline   Reply With Quote
Old 09-19-2016, 08:48 PM   #10
Clear tubing
Seems like every trip during our 1st year in the new Forester . . . rain, rain, rain ! ! Added a 6" clear tube over the end of the gutter and put on screw in it to hold everything in place. No more rain (or AC) in our door switches.
texasbuckeye is offline   Reply With Quote
roo, roof, water
