03-29-2015, 11:32 PM
Water tank drain ?
Next to the tank blue drain hose there is a red hose that has a cap screwed on the end. They run side by side and out the floor next to the water pump. Can't figure what it's for. 2014 forester 3011ds.
03-30-2015, 12:39 AM
GLCM Warrior
Most likely those are your low point drains. Used to drain the water out of the piping in the RV. I typically drain my system anytime it is going to sit for more than a few days.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
03-30-2015, 09:07 AM
Red would be hot water, blue is cold water low point drain.
03-30-2015, 09:55 AM
Sounds like you may have the same set up as my unit. Blue is tank drain and red is low point drain (hot and cold). When the wh bypass is set for winterizing, both the hot and cold lines are tied together and therefore only one low point drain is required. If this is your set up both of those (re/blue) lines should have removal caps/plugs.
03-30-2015, 11:02 AM
Thanks that makes sense. Struck me as odd that one has a valve only and the other has a screw cap only.
Appreciate the help
03-30-2015, 11:37 AM
Normally you have a blue and a red line sticking out with caps on them. Both are low point drains, red for hot and blue for cold and a valve to drain the fw tank.
03-30-2015, 12:47 PM
Old Cool do you meat 3 total? I only have the 2
03-30-2015, 12:55 PM
I think he does, I have 3 total as well.
2 low points and one fw drain.
TURBS
08 duramax tuned n modded, 32bhok Sabre
03-30-2015, 01:08 PM
As I said, I have a blue with cap, a red with cap and a valve to drain the tank.
1 valve and 2 caps.
03-30-2015, 03:25 PM
My Wildcat has 1 blue with cap to drain FW tank... 1 red with cap low point hot drain... 1 blue with cap low point cold drain. I should install a valve on the FW drain if not all 3.
03-30-2015, 04:01 PM
Average Joe
On my Sunseeker, the capped red line is the low point drain. The blue line without a cap has a valve and it's the fresh water tank drain.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
03-30-2015, 04:09 PM
Thats the same as my 3051 and should be the same as OP's
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
