Old 04-08-2015, 06:30 PM   #1
Waterpur Filter
New to RVing and just bought a new Forester. Where does the Waterpur filter go? How often should I change filters? Thanks.
steveadamcik is offline   Reply With Quote
Old 04-08-2015, 06:47 PM   #2
I change mine once a year can't help with location but try looking where the fresh water tank is located
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 04-08-2015, 06:48 PM   #3
Btw. Welcome to the forum!!!
Jerry. Vietnam vet.
Retired
Old 04-08-2015, 06:49 PM   #4
Average Joe
MrJoe's Avatar
Depending on your model, filter housing may be beside your water pump. I change my main filter once a year. Here's the place I get my replacements WaterPur Filters
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 04-08-2015, 07:10 PM   #5
lgray's Avatar
Better read this string before ordering...
The KW1 Water Filter Myth
lgray is offline   Reply With Quote
Old 04-08-2015, 07:19 PM   #6
Average Joe
MrJoe's Avatar
His unit takes the CCI-10-Ca filter, not the KW1. I personally like the CCI-10-Ca and have zero complaints with flow or water quality.
Joe and Karen
Old 04-08-2015, 07:26 PM   #7
Boso's Avatar
Mine is located passenger side next to last storage bin behind little panel 3050
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 04-08-2015, 07:32 PM   #8
When I got my MH there must have been a very low micron/low flow filter in it. When I was using the water pump the tap pressure would surge because the pump was cycling on /off.This only happened on pump , city water connection worked fine. I removed the on board filter and the pump worked properly.I checked the flow rate of the pump and it was putting out proper rate.Now I just use a inline filter now and everything is good.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-17-2015, 10:11 AM   #9
ourflat's Avatar
I change my filter out twice a year and keep a spare in stock just like I would do on my 2000 Fleetwood Tiago Arrow. Don't forget to check the RV water pump see through screen once in awhile to ensure no contaminants are restricting your flow while using the onboard water pump. I often find the strangest things in that pump filter!
Frank
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
water
