Old 07-03-2018, 03:41 PM   #1
Bezzola's Avatar
What is this
This is above my bedroom slide by the awning arm can anyone tell me what it is for its the piece screwed to the wall Click image for larger version
Bezzola is offline   Reply With Quote
Old 07-03-2018, 03:43 PM   #2
PPST Wannabe
kenandterry's Avatar
I believe itís part of the locking mechanism to keep the slide in when retracted.
I could be wrong.....my wife says I am quite often 🤔🤔
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-03-2018, 03:50 PM   #3
Jeff
Jcf0527's Avatar
Itís part of the anti-billow system. The other part is that little arm sticking off the roller. If the wind starts to unroll the awning that arm will rotate and catch on the ledge of the piece attached to the trailer wall, preventing it from going further and unrolling more. When you put the slide out, itís moved far enough away from the wall by the time the arm gets pointed towards the wall that it misses the ledge.
I hope that makes sense.
Jeff & Peggy
2017 Coachmen Leprechaun 319MBS
Avid campers since 1999
Jcf0527 is offline   Reply With Quote
Old 07-03-2018, 08:16 PM   #4
Duckogram's Avatar
X2 (and yours arm is not mounted exactly where it should be but its close enough)
ILB ( | )
Old 07-03-2018, 08:28 PM   #5
Jeff
Jcf0527's Avatar
Hmmm -thatís where mine is as well. I thought it was in the wrong place as well but the dealer said that gives just a bit of play but stops anything significant. Plus if it were too close to the stop the roller would catch as the slide starts out.
Jeff & Peggy
Old 07-04-2018, 09:18 AM   #6
Duckogram's Avatar
High Noon is the sweet spot. That does not mean it will not work in other positions. It just will not be “perfect”.
https://cdn.ltvdns.com/leisurevans.c...structions.pdf
ILB ( | )
Old 07-04-2018, 11:06 AM   #7
Bezzola's Avatar
That makes sense thanks for the info.
