Old 02-05-2017, 03:49 PM   #1
What's This? Awning Strap
Our 2015 Forester 2401R had this in the glove compartment. I've been carrying it around ever since but with no idea what it is, or if it is of any use at all. The picture shows the two ends of a light fabric belt about 6 feet long and about 1 inch wide. And yes I'm prepared to be insulted! Click image for larger version
2015 Forester 2401R
Silver Spring, MD
Wormturner is offline   Reply With Quote
Old 02-05-2017, 03:52 PM   #2
Darmo15's Avatar
I think it is the strap to unroll your awing.
Daryl
2014 Georgetown 351ds
Darmo15 is offline   Reply With Quote
Old 02-05-2017, 03:55 PM   #3
Director, FROG
F.R.O.G.'s Avatar
Exactly right. For a non-motorized awning, insert the metal pin inside the slot at the end of the awning, and slide the strap over to the center, so that the pin in inside the roller and the strap is hanging out and rolls up with the awning.
There might also be a metal pole about four feet long with a hook on the end to hook into the loop on the strap and pull the awning open. Also use it to hold the awning strap as the awning gets close to being fully rolled up.
No insult required or even appropriate.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 02-05-2017, 04:23 PM   #4
Wow, I should have known you guys would know! Ok, I'll keep it handy. Thanks!
2015 Forester 2401R
Silver Spring, MD
Old 02-05-2017, 04:37 PM   #5
wmtire's Avatar
Here is a video of it in play in your awning:
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 02-05-2017, 04:53 PM   #6
wmtire's Avatar
Oh, I forgot to add, you probably have electric power awnings. This strap is to be used in case of motor failure...which is why it's in your glove box and not on the awning.
This link (although not maybe your particular awning) explains this emergency use strap on pages 7-8:
http://liferebooted.net/life-reboote...g%20Manual.pdf
Old 02-06-2017, 09:13 PM   #7
Chief tinkerer
Gidyupgo's Avatar
I have found it useful as an awning tiedown on a couple of occasions. I know, I know, that's not what its for....
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 02-07-2017, 07:27 AM   #8
Well that's interesting! I have not had time to think about how to get the awning down if the motor or switch is not working. So then, are all FR RV's with Dometic power awnings also supposed to come with a strap? If so, mine did not.
newRVer is offline   Reply With Quote
Old 02-07-2017, 07:34 AM   #9
wmtire's Avatar
On the electric awnings, it's actually for getting the awning retracted in case of motor failure. That way you can get home or to a repair facility and the strap now rolled up in the awning will allow you to pull it out (if even necessary) and get the motor fixed.
If the motors fail when the awning is retracted, then it's not a problem until it can be fixed, and the RV can still travel. No need for the strap.
Without the strap already rolled up in the awning, the awning CAN be rolled out, but it's not something that one man is going to want to try and do at a campground by themselves and without ladders.
As far as if they are "supposed" to come with the strap, I cannot answer. Mine did, and was in the bag of stuff with the manuals, antifreeze injection hose, water filter canister wrench, etc.
I also renamed this thread title to help those in the future who may do a search on it.
P.S. This is a good example of something else that many RV'ers aren't aware of. While it is the off-camping season, it would be a good time to actually learn how to do things like this in case of failure/emergency. Learn how to retract the electric awning, retract your slides, retract your electric stabilizers, retract your electric tongue jack (if equipped). All these items have manual over rides and tools that are used to accomplish this. It would be time well spent to study up on these, and make sure you know where the tools are located (and you have them).
If you don't know how and/or have the tools to accomplish these feats, then you are going to be at the mercy and time of someone else who does.
Old 02-07-2017, 08:29 AM   #10
I have an electric awning and the strap came included separately in my FR Owner's Kit.
It is to be used in case the awning fails in the open position.
In my case I needed to insert the strap and then back up my truck under the forward part of the opened awning. I then climbed up and removed 2 bolts (per the awning manual) having DW hold the strap for when the awning snapped back to the closed position.
As it turned out, NOTHING happened. Motor had frozen, but I was able to hand roll up. Later replaced by FR under my second year FR warranty.
2015 Shamrock 231KSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017, 37 in 2018
CNYCamper is offline   Reply With Quote
