Old 06-22-2019, 08:34 AM   #1
Question Where are the power connections?
Trying to find the power connections for the shore power and transfer switch.
I'm trying to install a Progressive on board EMS-HW30C and can't find where the connections are for the shore power.
2019 Forester 3011 DS
2015 Jayflight 28BHBE (sold)
2015 Ram 2500 Megacab 4x4 6.4 L Hemi 4.10 gearing
"Is this a game show?"
sugarray40 is offline   Reply With Quote
Old 06-22-2019, 01:23 PM   #2
A32Deuce's Avatar
Mine is under the bed that isn't on a slide.
A32Deuce is offline   Reply With Quote
Old 06-26-2019, 11:21 AM   #3
Mine is also under the bed. I installed my hw30c between the transfer switch and the circuit breaker box to cover both shore power and generator power.
Badabbotts is offline   Reply With Quote
Old 06-26-2019, 11:29 AM   #4
A32Deuce's Avatar
You don't need to cover the generator but you left your transfer switch un protected.
Old 06-26-2019, 11:55 AM   #5
2 things if the ems does not see "clean" power there is no current flow, so the transfer switch is not unprotected, and secondly generators do not always provide clean power, over voltage, under voltage, less than/more than 60 cycles.
Old 06-26-2019, 11:59 AM   #6
I would pull the panel out and look for #10 romex behind it and see where it goes. You might even find space behind the panel for the EMS. I mounted ours beside the panel and re-routed the #10 romex into the EMS. But, it was right under a dinette seat and super-easy to access. Yes, you want an EMS wired after the transfer switch and shore power connection so power from either goes through the EMS.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
power
