Originally Posted by Wolverine 1945
WOW !!!
I did not realize that FR had started hiding the drain valves !!!
Ours was the first "W" our dealer had seen and it took two techs and a supervisor to find the fresh water drain...
Fast forward to late fall and we repeated the same process locating the low drain points! It doesn't help that they can slide all over the place in an area you can't see...
It was posted here that the drains were behind the side step and I "assumed"
that was correct and they were just buried in all the spray on foam. After digging out most of the foam I found out that little tidbit wasn't correct for the "W" variant of the MBS...
